vaisakhg SEFI Member
Joined: 11 Dec 2008 Posts: 18 Location: Kollam, Kerala, India
Posted: Mon Dec 22, 2008 7:28 am Post subject: Moment transfer columns to slabs |
Sir,
I came across a confusion whether the moment transfer from slabs to columns is to be considered in case of checking the punching shear. In usual practice, as i know, only the axial load is considered. But from literatre, i came across the fact that some portion of the moment is transfered by the eccentricity of shear. if that is the case that had to be added to the shear stress. Can you please give me a guidance?
Yours truly,
Vaisakh G
+971 50 6844981
pankajgrai at gmail.com Guest
Posted: Mon Dec 22, 2008 8:31 am Post subject: Moment transfer columns to slabs |
Dear Vaisakh,
According to me best solution is to design Column strip as an foundation and apply all the checks.
On Mon, Dec 22, 2008 at 1:36 PM, vaisakhg <forum@sefindia.org (forum@sefindia.org)> wrote:
Yours truly,
Vaisakh G
+971 50 6844981
sahi SEFI Member
Posted: Mon Dec 22, 2008 8:51 am Post subject: Moment transfer columns to slabs |
ADD to shear as you said. At least it will be conservative.
Yours truly,
Vaisakh G
+971 50 6844981
rahulganguli29 ...
Posted: Mon Dec 22, 2008 10:04 am Post subject: Moment transfer columns to slabs |
Dear Vaisakh,
Actually, if you considered the slab as beam, (since both are flexure member) so as per laws of equilibrium, the beam moment should equalise by coloumn in case of both are riigid together. Therefore this moment should be considered to design coloumn. Again on the other hand compressive load on coloumn should not act in center of coloumn cross section properly, distance between acting position of load and c.g. of coloumn is called ecentricity, and a moment is induced on coloumn due to this ecentricity. If you considered a free body diagram of this moment performance, you can understand this much better.
- Rahul
Yours truly,
Vaisakh G
+971 50 6844981
Posted: Tue Dec 23, 2008 7:31 am Post subject: Moment transfer columns to slabs |
My question is not about the moment that is caused in the columns by the eccentricity of loads. But it was about the transfer of unbalanced moments at the slab - column intersection. I had seen in literature and in ACI 318-05 about this. It is said that arround 40% of the unbalanced moment is transfered by the eccentricity of shear, which means the shear stress at the critical section is the sum due to the normal punching shear and the extra stresses said above.
This was exactly my question.
Yours truly,
Vaisakh G
+971 50 6844981
On Tue, Dec 23, 2008 at 11:06 AM, rahulganguli29 <forum@sefindia.org (forum@sefindia.org)> wrote:
[quote] Dear Vaisakh,
- Rahul
On Mon, Dec 22, 2008 at 1:36 PM, vaisakhg forum@sefindia.org (forum@sefindia.org))> wrote:
naveen SEFI Member
Posted: Wed Dec 24, 2008 5:13 am Post subject: Moment transfer columns to slabs |
Dear Mr. Vaisakh, Please refer " Reinforced Concrete : Mechanics and Design- James G. Macgregor" . This topic has been dealt in this book by neat sketches.
Naveen.
On Tue, Dec 23, 2008 at 1:30 PM, vaisakhg <forum@sefindia.org (forum@sefindia.org)> wrote:
Yours truly,
Vaisakh G
+971 50 6844981
On Tue, Dec 23, 2008 at 11:06 AM, rahulganguli29 forum@sefindia.org (forum@sefindia.org))> wrote:
- Rahul
On Mon, Dec 22, 2008 at 1:36 PM, vaisakhg (forum@sefindia.org)forum@sefindia.org (forum@sefindia.org) ( (forum@sefindia.org)forum@sefindia.org (forum@sefindia.org)))> wrote:
ksant26 SEFI Member
Posted: Thu Dec 25, 2008 3:45 pm Post subject: Moment transfer columns to slabs |
Dear all,
Yes we do required to transfer unbalanced bending moments in columns by taking care of punching shear. Please do refer CP110 for the formulation of punching shear check, as indian code is very silent on it. This is perhaps very critical check most of the engineer do forgot to check.
I like to ask all of you guys.
DO FLAT SLAB TAKES PARTICIPATION IN TRANSFERING SEISMIC LOADS?
IF YES ARE WE DESIGNING FOR THE SAME.
METHOD OF DISTRIBUTION OF FORCES AS PER STIFNNES OF MEMBERS TRANSFERS HEAVY FORCES ON SHEAR WALLS, AND THE COLUMNS JUST ACTS AS A PROPED ONE,. FOR HOW MUCH ACCURACY THIS PHENOMENON IS VALID?
CORRECT ME IF I'M WRONG.
AS PER MY THINKING GOES, EVERY FLOOR SLAB TRANSFER LOAD ON COLUMNS ON WHICH IT IS RESTING. SO THERE IS TRANSFER OF BENDING MOMENTS ALSO APART FROM VERTICAL LOAD. FLAT SLAB ALSO TAKE PART IN TRANSFERING LATERAL LOADS, I.E SHEAR AND BENDING MOMENTS. WE REQUIRED TO CHECK FOR THE SAME WHILE DESIGNING. AS MOST OF THE CONSULTANTS DESIGN THE FLAT SLAB ONLY FOR VERTICAL LOADS AND NOT FOR LATERAL LOADS.
THE POST TENSIONING FIRMS ALSO DESGIN SLABS FOR VERTICAL LOAD.
WE REQUIRED TO TRANSFER MOMENTS CONTOURS TO THEM FROM ETABS OR SIMILAR SOFTWARES TO ACCOMMODATE LATER FORCES OR CRTICAL BENDING MOMENTS AND SHEEAR.
REGARDS
SANTOSH KADAM
--- On Tue, 12/23/08, naveen <forum@sefindia.org> wrote:
[quote]
Subject: [ECONF] Re: Moment transfer columns to slabs
To: econf@sefindia.org
Date: Tuesday, December 23, 2008, 9:40 PM
Naveen.
On Tue, Dec 23, 2008 at 1:30 PM, vaisakhg forum@sefindia.org)> wrote:
Kedar SEFI Regulars
Posted: Sun Dec 28, 2008 3:22 pm Post subject: |
Hi
Vaisakhg
Can u plz share the reference material from where u got
info regarding moment in column due to shear?for PT slab.
Kedar |
ibarua General Sponsor
Posted: Tue Dec 30, 2008 12:40 pm Post subject: Moment transfer columns to slabs |
30 Dec 2008
For Mr Kedar:
You can get details in RCC Design Handbook by Mark Fintel & others. But do use the formulae given in IS:456 rather than those given in the ACI Code. You can easily write a spreadsheet to solve your problem.
Happy New Year.
Indrajit Barua. On Sun, 28 Dec 2008 Kedar wrote :
Quote: | Hi
Vaisakhg
Can u plz share the reference material from where u got info regarding moment in column due to shear?for PT slab.
regards Kedar
Posted: Tue Dec 30, 2008 1:40 pm Post subject: Moment transfer columns to slabs |
it is there in ACI 318-05
but i was not talking about the moment caused by shear but about the moment transfer between slabs and columns.
Also it is in referance to flat slab in general and not in particular referance to PT slabs
Yours truly,
Vaisakh G
http://vaisakhg.googlepages.com
http://www.orkut.com/Profile.aspx?uid=7580923768115555776
+971 50 6844981
On Sun, Dec 28, 2008 at 7:22 PM, Kedar <forum@sefindia.org (forum@sefindia.org)> wrote:
Quote: | Hi
Vaisakhg
Kedar
