alpa_sheth ...
Posted: Mon Jul 21, 2003 5:06 pm Post subject: [ECONF] Indian codes do not encourage economy in design |
Dear Pankaj,
I did not perhaps respond earlier, so I will now ))
Quote: | 1) A lot of clauses in the Indian codes in general and 1893:2002 in specific, are ambiguous and open ended which lead to multiple interpretations. I do not know, why this is so, but it is a very undesirable situation, and should be dealt with head on (in no ambiguous terms).
| I completely agree with you that any ambiguities in the codes should be clarified in an amendment immediately rather than wait for a new revision to come, which may be two decades later.
Quote: | 2) In cases of ambiguity, the general response in most of the cases is to nterpret it towards the CONSERVATIVE side, without application of either rational & scientific thought process....... A classic case is this topic of load combinations. If we consider the UBC 1997, we will see that all the load combinations given (clause 1612.2.1, page 2-4, vol II) are far less conservative than those given in Indian codes, and the reason being that they are far more scientifically rational & logical, and not based on an irrational fear for "lack of safety".
I thought the Indian load combinations are pretty much on par with those elsewhere if one takes into account the ultimate vs limit load systems of design. I do know that from time to time the IS codes do change their criteria based on more data/debate. I remember for example that the change in critical section for shear check in pile caps has been considerably relaxed in the 2000 version of IS 456. I am not sure about Indian codes being oversafe. I am really shockd for example that our IS 13920 still does not have a requirement of strong column weak girder. In that it is very unconservative rather than conservative.
Quote: | 3) Our codes are pathetically lacking the adequacy to meet the requirements of the new millenium. They seem to have an ostrich like attitude towards computerized calculations and their ability to provide optimizations in a short time frame. Just because ALL of us in India do not have the means to have the right tools or are not ready to apply their minds & efforts, should not be a reason for a penalty to those who have the tools and are effectively using them to create a more rational & economical structural system. The present day formulations, clauses & guidelines of the Indian codes DO put such a penalty, specially in the cases of peer review & checking by government engineers. Again a classic case is the emperical formulae for time period of the building "WITHOUT infill panels" as given in IS:1893:2002 opposed to the results you get by ANY software. "WITH the panels" case may be debatable to some extent, but "WITHOUT the panels" case has no justification of being so outrightly unconservative in the year 2002.
You have an interesting viewpoint but I'm not sure I share it. One the contrary, I am increasingly dismayed at the dependence on computers that the new codes are imposing on the structural engineer. WIth a requiremnt of designing for 1.5 eccentricity + 5% building dimension as eccentricity for seismic load design for a single storey building in Zones III to V, even designing a single storey building has become rocket science.
The requirement of empirical formulae for time period is based on hundreds of in-situ testing and exists even in IBC for that matter. ANd then don't you think building loads keep changing over the liftime of a building? Walls are knocked off or built, changing stiffness to a large degree without any thought. So it does make sense to have empirical formulae....
Regards, Alpa
Quote: | ******************** Regards
Pankaj Gupta |
