Delhi airport Terminal T3
PostPosted: Thu Jul 08, 2010 3:40 pm    Post subject: Delhi airport Terminal T3 Reply with quote
Hi All,
Delhi airport Terminal T3 was dedicated to the nation a few days ago.
Click on the video on the following link to know about the details and be proud of our achievements!
http://www.newdelhiairport.in/media.aspx
atul_123
PostPosted: Wed Jul 28, 2010 7:37 am    Post subject: Reply with quote
On Wednesday, international flights are supposed to start operating from Indira Gandhi International Airportís brand-new Terminal 3. In the run-up to the switch, one image has dominated coverage of the addition to the GMR-run New Delhi airport: The installation of a series of giant hands jutting from a wall of what look like copper discs along T3ís main concourse.
Indian industrial design firm Incubis Consultants, and U.S.-based branding company Landor Associates shaped the artistic choices for the terminal and settled upon the idea of the hands, which were made and installed by Jaipur-based designer Ayush Kasliwal. Here are edited excerpts from a conversation with Incubis head Amit Gulati.:
IRT: How did you come up with the design?
Gulati: It was a bit of a team effort. There was a lot of brainstorming done on it. This artwork is part of a larger process of creating design installations and graphics within the terminal. Itís the largest, so itís hogged all the limelight.
GMR has built a pretty world-class infrastructure over here. All airports have very similar design vocabulary. They are actually machines. They tend to evolve in a similar glass and metallic fashion. Very early on they were keen to give the terminal an Indian context and infuse it with Indian values. The basic positioning we created for the terminal was ďExpressive India.Ē All classical Indian dance forms use mudras [hand gestures]. Itís a common vocabulary.
Courtesy of Incubis ConsultantsThe art installation of classical hand gestures.
IRT: So itís not a Hindu-themed piece? It looked a little religious to us.
Gulati: That was an important consideration.  We have deliberately avoided any religious motif [in the hand gestures chosen]. They represent an open-ended symbology rather than a religious philosophy. I would say the mudras are not really Hindu in themselves. They represent them in Buddhist art, Southeast Asian art uses the same kind of mudras.It also ties in with the whole idea of yoga, which is again very global. Yoga also has religious undertones but itís perceived as a secular thing.
In India itís very difficult to find something thatís very secular. Even the Ashoka Pillar you can construe as a religious symbol, but itís the symbol of the government. So itís really about the meanings of the mudras, itís about how a person from abroad would see these as Indian rather than Hindu or Muslim.
IRT: What is it made of?
Gulati: First we had a sculptor make them in clay ó we used a lot of traditional craftsmen.
There was a master model of the hand made in clay. The inspiration was a female hand but also using the inspiration of classical chola sculptures. The clay model was converted into a plaster mold and then the inverse hand poses were cast using resin. It had to be resin otherwise it would have been too heavy but we used a metallic finish. The discs you see flanking the mudra are spun aluminum with copper coating.
IRT: How much does it weigh?
Gulati: There are 675 discs mounted on a cast aluminum structure [called a spider]. One spider holds three discs Ė itís basically an aluminum structure shaped like the Mercedes-Benz symbol, a three-pointed star [A spider with three discs weighs about 50 kilos, Mr. Gulati said via e-mail later]. Each hand weighs approximately 150 kilograms because of the metal frame inside the resin.
IRT: Whatís your favorite gesture of the nine depicted?
Gulati: There is a mudra called the abhaya mudra [the fearless gesture], which is actually one of the simplest mudras: An open hand and the fingers are bent slightly almost like someone is trying to reach out. Thatís a very nice gesture. Itís not a flat hand, itís not a fully formed gesture, itís in the middle somewhere ó itís almost like itís touching you.
DIALmudras.pdf
 Filename:  DIALmudras.pdf
 Filesize:  423.22 KB
 Downloaded:  489 Time(s)
