inchak at tatasteel.com Guest
Posted: Fri Jul 01, 2005 11:54 am Post subject: Draft Modification of IS 1786 |
Dear all
The CED 54 of the Bureau of Indian Standards is right now undertaking the job of a major revision of IS:1786 - the specification for High Strength Deformed Steel Bars and Wires for Concrete Reinforcement.
The draft proposal is available in the following URL.: http://www.bis.org.in/sf/ced/p_7303.pdf
I take this opportunity to draw the attention of all participants of this august forum to examine the draft document carefully and comment on the same. Comments may also be sent directly to Mr. Amandeep Garg, the Member Secretary of CED 54, BIS, Delhi whose email ID is given below. aman@bis.org.in
In effect, the draft is trying to introduce a set of new subgrades captioned with the letter D in Fe 415, Fe 500 and Fe 550 grades, which indicate extra ductility. If you see the table3 in the page 10 of the document, you would notice that the elongation level required for the D grade has been fixed at 14.5% for all the 3 grades, which may be a step in the right direction. However, in case of Fe 415 grade both the D variety and the ordinary variety have the same elongation value of 14.5%, which is probably not right.
With this note I request the views of the structural engineers whether it helps to specify a minimum limit of elongation at 18% for Fe 415 grade. Any views?
Other steps which are in the right direction for the D grade are:
1) A higher ratio between tensile strength and yield strength has been stipulated. 2) An uniform elongation of 5% has been stipulated.
This is the right time to generate all possible opinions on this subject.
Please contribute your views liberally.
********************************DISCLAIMER*********************************** Information contained and transmitted by this e-mail is confidential and proprietary to Tata Steel Ltd. and is intended for use only by the addressee. If you are not the intended recipient , you are notified that any dissemination or copying of this e-mail is strictly prohibited and you are requested to delete this e-mail immediately and notify the originator. Tata Steel does not enter into any binding agreement with any party by e-mail. Any views expressed by an individual do not necessarily reflect the view of Tata Steel. Tata Steel is not responsible for the consequences of any actions taken on the basis of information provided. While this e-mail has been checked for all known viruses the addressee should also scan for viruses. To know more about Tata Steel please visit www.tatasteel.com ********************************************************************************
