inchak at tatasteel.com Guest
Posted: Tue Jul 05, 2005 11:45 am Post subject: Super Ductile Rebars for enhanced protection to RCC structur |
When a structure is subjected to earthquake, it receives severe shock (impact) loading. The ability of the structure to survive the earthquake depends entirely on its ability to absorb the energy of the impact. In a RCC structure steel has to do the work of energy absorption without fracture. It is well known that the area under the engineering stress - strain curve represents the energy absorbed by the steel before it fractures. It is therefore, possible to recommend various stipulations to suitably 'tailor' the stress - strain curve, so that a high ability to absorb energy is intrinsically assured.
We at Tata Steel have studied various international specifications to understand how the stress - strain curve is tailored in different countries and have synthesised all these specifications to come out with a new offering named as 'Super Ductile Rebars'.
For the purpose of this note we will compare various features of the stress - strain curve with those specified in IS:1786 (Fe 415 grade), Euro Norm, ASTM A706 (Gr 60) and the combined Australia and New Zealand code (Gr 500 N and NE).
1) YIELD STRENGTH (MPa) Min. which decides the design load IS 1786(Fe 415) - 415 Euronorm - 450 ASTM A706 (GR 60) - 420 Australia / New Zealand (500 N) - 500 Australia / New Zealand (500 NE) - 500 TATA STEEL Super Ductile Rebars - 415
2) YIELD STRENGTH (MPa) Max. Some, but not all specifications put a cap on the maximum permissible yield strength. The idea is that the bar should not unduly resist plastic deformation (yielding) thus allowing excessive stress to build up in the concrete. The various specifications stand thus: IS 1786(Fe 415) - NA Euronorm - NA ASTM A706 (GR 60) - 540 Australia / New Zealand (500 N) - 650 Australia / New Zealand (500 NE) - 600 TATA STEEL Super Ductile Rebars - 500
3) ULTIMATE TENSILE STRENGTH (MPa) Min. This value should be appreciably higher than the yield strength so that the strength of the bar (and, therefore, its ability to bear load) continuously increases as it deforms plastically under gross overload conditions. The values for the various specifications are indicated below: IS 1786(Fe 415) - 10% higher than YS Euronorm - 15% higher than YS ASTM A706 (GR 60) - 550 Australia / New Zealand (500 N) - 8% higher than YS Australia / New Zealand (500 NE) - 15% higher than YS TATA STEEL Super Ductile Rebars - 20% higher than YS
4) ULTIMATE TENSILE STRENGTH (MPa) Max. Same comments as for the YS maximum - point 2 above. IS 1786(Fe 415) - NA Euronorm - 35% higher than YS ASTM A706 (GR 60) - NA Australia / New Zealand (500 N) - NA Australia / New Zealand (500 NE) - 40% higher than YS TATA STEEL Super Ductile Rebars - 50% higher than YS
5) % UTS / YS RATIO (Min.). This is point 3 and 4 expressed in another way. For a given yield strength level it can be easily visualised that the higher is the UTS to YS ratio the larger becomes the area under the stress - strain curve. IS 1786(Fe 415) - 1.10 Euronorm - 1.15 - 1.35 ASTM A706 (GR 60) - 1.25 Australia / New Zealand (500 N) - 1.08 Australia / New Zealand (500 NE) - 1.15-1.40 TATA STEEL Super Ductile Rebars - 1.20
6) % ELONGATION (Min.). This is the prime measure of the ductility of steel and therefore, its ability to absorb energy. This number should be as high as possible. Some specifications do not mention this because they have more faith in uniform elongation as discussed in the point 7 below. IS 1786(Fe 415) - 14.5 Euronorm - 7.5 ASTM A706 (GR 60) - 10 - 12 (depending on size) Australia / New Zealand (500 N) - NA Australia / New Zealand (500 NE) - NA TATA STEEL Super Ductile Rebars - 18%
7) % UNIFORM ELONGATION UPTO MAX. STRESS (Min.). This is an extremely important measure, which stipulates the elongation that the bar must demonstrate before it reaches its maximum strength and necking starts. It can be well appreciated that once the necking starts the steel may elongate much more. But eventually it WILL break. The position of various specifications with respect to this parameter is presented below: IS 1786(Fe 415) - NA Euronorm - NA ASTM A706 (GR 60) - NA Australia / New Zealand (500 N) - 5 Australia / New Zealand (500 NE) - 10 TATA STEEL Super Ductile Rebars - 8
It is well known that sulphur, phosphorous and carbon should be restricted to make steel tougher. The restriction with respect to these are also presented below:
% CARBON (Max.) IS 1786(Fe 415) - 0.30 Euronorm - 0.22 ASTM A706 (GR 60) - 0.30 Australia / New Zealand (500 N) - 0.22 Australia / New Zealand (500 NE) - 0.22 TATA STEEL Super Ductile Rebars - 0.25
% SULPHUR (Max.) IS 1786(Fe 415) - 0.060 Euronorm - 0.050 ASTM A706 (GR 60) - 0.045 Australia / New Zealand (500 N) - 0.050 Australia / New Zealand (500 NE) - 0.050 TATA STEEL Super Ductile Rebars - 0.040
% PHOSPHORUS (Max.) IS 1786(Fe 415) - 0.060 Euronorm - 0.050 ASTM A706 (GR 60) - 0.035 Australia / New Zealand (500 N) - 0.050 Australia / New Zealand (500 NE) - 0.050 TATA STEEL Super Ductile Rebars - 0.040
The purpose of this note is to invite opinion from all the experts participating in this e-conference on this new offering from Tata Steel.
