admin at sefindia.org Guest
Posted: Mon Jul 04, 2005 12:08 pm Post subject: Pull Out Test Table from Mr. Indranil Chakrabarti |
PULL OUT TEST RESULT OF TMT BARS
FOR 0.025 MM Slip (Specified Ratio 140%)
Size Load Plain Load TMT Actual Ratio of Load for (mm) (Kg) (Kg) TMT / Plain bar (%)
8.00 125 450 360 10.00 120 210 175 12.00 290 470 162 16.00 610 940 154 20.00 650 1160 178 36.00 1280 3100 242
FOR 0.25 MM Slip (Specified Ratio 180%)
8.00 310 1305 421 10.00 615 1400 228 12.00 1190 2270 191 16.00 1650 4030 244 20.00 3600 8630 240
sanyojan SEFI Member
Posted: Fri Jul 08, 2005 6:34 am Post subject: Pull Out Test Table from Mr. Indranil Chakrabarti |
I have not received a single mail since the e-conf started. Kindly send me the condensed versions of the conf of all the days.
Anand Bhagwatwar
