Message No 32 - Guaranteed min & Max strength of rebar
This forum is locked: you cannot post, reply to, or edit topics.This topic is locked: you cannot edit posts or make replies.    www.sefindia.org Forum Index -> E-Conference 20th June 2005
inchak at tatasteel.com
PostPosted: Tue Jul 12, 2005 10:31 am    Post subject: Message No 32 - Guaranteed min & Max strength of rebar Reply with quote
Dear Mr. Vipul Ahuja,
Excellent point
I reproduce your concern
QUOTE
Back in the 80's in the US,a need felt among structural engineers for
weldable "Tor" steel to be available to them that not only had a guaranteed
minimum strength but also a maximum strength. The reason was that in order
for the strong column weak beam theory to be implemented properly the beam
steel could not be stronger than the column steel in terms of material
strength. Also weldability avoided the usual site problems. The answer from
the industry to this was ATMS A706 bars.
Do we have an IS equivalent to this and if not is there any hope in the
near future.
UNQUOTE
You are quite correct.
BIS does not have any upper limit on strength. Only lower limt is there.
However we have realized the importance of this upper limit and offered to
provide BOTH upper and lower limits to the Yield strength in line with not
only the ASTM A 706 but also the Australia / New Zealand code   as follows:
1) YIELD STRENGTH (MPa) MIN. which decides the design load
IS 1786(Fe 415) - 415
Euronorm - 450
ASTM A706 (GR 60) - 420
Australia / New Zealand (500 N) - 500
Australia / New Zealand (500 NE) - 500
TATA STEEL Super Ductile Rebars - 415
2) YIELD STRENGTH (MPa) MAX. Some, but not all specifications put a cap on
the maximum permissible yield strength. The idea is that the bar should not
unduly resist plastic deformation (yielding) thus allowing excessive stress
to build up in the concrete. The various specifications stand thus:IS
1786(Fe 415) - NA
Euronorm - NA
ASTM A706 (GR 60) - 540
Australia / New Zealand (500 N) - 650
Australia / New Zealand (500 NE) - 600
TATA STEEL Super Ductile Rebars - 550
Please let me know if you find this to be a step in the right direction.
However to get it incorporated in the Indian Specification(s) you need to
initiate the process with the Bureau of Indian Standards.
********************************DISCLAIMER***********************************
Information contained and transmitted by this e-mail is confidential and
proprietary to Tata Steel Ltd. and is intended for use only by the
addressee. If you are not the intended recipient , you are notified that
any dissemination or copying of this e-mail is strictly prohibited and you
are requested to delete this e-mail immediately and notify the originator.
Tata Steel does not enter into any binding agreement with any party by
e-mail. Any views expressed by an individual do not necessarily reflect the
view of Tata Steel. Tata Steel is not responsible for the consequences of
any actions taken on the basis of information provided. While this e-mail
has been checked for all known viruses the addressee should also scan for
viruses. To know more about Tata Steel please visit www.tatasteel.com
This forum is locked: you cannot post, reply to, or edit topics.This topic is locked: you cannot edit posts or make replies.    www.sefindia.org Forum Index -> E-Conference 20th June 2005 All times are GMT
