e-Conference on Steel Reinforcement from June 27 to July 17,
This forum is locked: you cannot post, reply to, or edit topics.This topic is locked: you cannot edit posts or make replies.    www.sefindia.org Forum Index -> E-Conference 20th June 2005
joshiconsultants9 at g...
Guest
PostPosted: Fri Jul 15, 2005 3:34 am    Post subject: e-Conference on Steel Reinforcement from June 27 to July 17, Reply with quote
Dear all,
The CED 54 of the Bureau of Indian Standards is right now undertaking the
job of a major revision of IS:1786 - the specification for High Strength
Deformed Steel Bars and Wires for Concrete Reinforcement.
I take this opportunity to draw the attention of all participants of this
august forum to examine the draft document carefully.
My views on the proposed Table 3 are as under
1. The ultimate stress should be at lest 1.25 times yield stress in D
category steel.
2. The minimum percentage uniform elongation should be at least 10%.
The total percentage elongation should be more than 14.5 percent for
Fe 415D grade steel.
3. Fe 550 and Fe 600 grade steel need not be introduced as this will
not serve any purpose for their use in earthquake resistant reinforced
concrete structures.
The relevant paper on this discussion is sent to admin@sefindia.org
for uploading.
Neelkanth D Joshi
Joshi Consultants
Consulting Structural Engineers
Mumbai
Joshiconsultants9@gmail.com
joshiconsultants@hotmail.com
This forum is locked: you cannot post, reply to, or edit topics.This topic is locked: you cannot edit posts or make replies.    www.sefindia.org Forum Index -> E-Conference 20th June 2005 All times are GMT
