Robert Mallet- Regarded as father of seismology
PostPosted: Fri Sep 14, 2012 7:25 pm    Post subject: Robert Mallet- Regarded as father of seismology Reply with quote
The Irish engineer and scientist Robert Mallet (1810–1881) is one of Ireland's many unsung scientific heroes. His contributions to the fields of engineering, seismology, volcanology and ballistic ordnance were of global significance. As 2010 saw the bicentenary of his birth, this exhibition highlights his leading role in solving critical scientific questions.
Mallet is regarded as the founder of seismology (the study of earthquakes) - amongst his many achievements, his pioneering experiments on Killiney beach during the 1840s showed for the first time how sound waves can shake the ground and cause catastrophic earthquakes.
Mallet was also involved in practical engineering projects, he devised an ingenious way of adding strength to metal without increasing its weight - known as ‘Buckled Plates’ this technique has been used in many famous bridges and buildings including Westminster Bridge in London. The Mallet family iron foundry business left an indelible legacy on the Irish landscape by supplying ironwork for the railways, the swing bridge over the River Shannon and even the iron railings surrounding Trinity College.
Mallet had a curious mind and an unlimited imagination, fundamental requirements for all great scientists. He was a true polymath and each panel of this exhibition reflects a different facet of his work; from ‘Buckled Plate’ bridges, earthquakes and seismology, to volcanoes, metal corrosion and giant mortars.
Biography
Robert Mallet FRS (3 June 1810–5 November 1881), Irish geophysicist, civil engineer, and inventor who distinguished himself in research on earthquakes and is sometimes called the father of seismology.
Early life
Mallet was born in Dublin, on 3 June 1810, the son of factory owner John Mallet. He was educated at Trinity College, Dublin, entering it at the age of 16 and graduating in science and mathematics in 1830 at the age of 20.
Career
Following his graduation, he joined his father's iron foundry business and helped build the firm into one of the most important engineering works in Ireland, supplying ironwork for railway companies, the Fastnet Rock lighthouse, and a swing bridge over the River Shannon at Athlone. He also helped manufacture the characteristic iron railings that surround Trinity College and which bear his family name at the base.
Mallet was elected to the Royal Irish Academy in 1832 at the early age of 22. He also enrolled in the British Association for the Advancement of Science in 1835 which helped finance much of his research in seismology.
In 1838 he became a life member of the Royal Geological Society of Ireland, and acted as its President from 1846–48.
From 1848-1849 he constructed the Fastnet Rock lighthouse, southwest of Cape Clear.
Seismological work
On 9 February 1846 he presented to the Royal Irish Academy his paper,On the Dynamics of Earthquakes, which is considered to be one of the foundations of modern seismology. He is also credited with coining the word "seismology" and other related words e.g. the isoseismal map, which he used in his research. He also coined the term epicentre.
From 1852 to 1858, he was engaged (with his son, John William Mallet) in the preparation of his work, The Earthquake Catalogue of the British Association (1858), and carried out blasting experiments to determine the speed of seismic propagation in sand and solid rock.
On 16 December 1857, the area around Padula, Italy, was devastated by the Great Neapolitan Earthquake which caused 11,000 deaths. At the time it was the third largest known earthquake in the world and has been estimated to have been of magnitude 6.9 on the Richter Scale. Mallet, with letters of support from Charles Lyell and Charles Darwin, petitioned the Royal Society of London and received a grant of £150 to go to Padula and record at first hand the devastation. The resulting report was presented to the Royal Society as the Report on the Great Neapolitan Earthquake of 1857. It was a major scientific work and made great use of the then new research tool of photography to record the devastation caused by the earthquake. In 1862, he published the Great Neapolitan Earthquake of 1857: The First Principles of Observational Seismology in two volumes; he brought forward evidence to show that the depth below the Earth's surface, from where the impulse of the Neapolitan earthquake originated, was about 8–9 geographical miles.
One of Mallet's papers was Volcanic Energy: an Attempt to develop its True Origin and Cosmical Relations, in which he sought to show that volcanic heat may be attributed to the effects of crushing, contortion and other disturbances in the crust of the earth; the disturbances leading to the formation of lines of fracture, more or less vertical, down which water would find its way, and if the temperature generated be sufficient volcanic eruptions of steam or lava would follow.
Other work
Mallet's Mortar with 36 inch shells which would have contained 217 kg of gunpowder.
During the Crimean War he designed a 43 t mortar of 36 inches (910 mm) calibre capable of throwing a 1,100 kg shell a distance of 2.4 km. The huge mortar was built in sections to allow transport, but was too late to be used in action. An example has been preserved at the Royal Artillery base in Woolwich and one is displayed before the Royal Armouries Fort Nelson near Portsmouth.
Mallet's Mortar with 36 inch shells which would have contained 480 lb (217 kg) of gunpowder.
Mallet was elected Fellow of the Royal Society in 1854, and moved to London in 1861. He was awarded the Telford Medal by the Institution of Civil Engineers in 1859, followed by the Wollaston medal of the Geological Society of London in 1877, the Society's highest award.
Blind for the last seven years of his life, he died at Stockwell, London, on 5 November 1881 and is buried at West Norwood Cemetery.
Source: http://en.wikipedia.org/wiki/Robert_Mallet
Also see:
  • http://www.australiandesignreview.com/features/17617-resilient-the-evolving-terminology-of-ecological-development
  • http://www.rds.ie/cat_project_detail.jsp?itemID=1096051
See also the enclosed PDF
Er Robert Mallet.pdf
 Filename:  Er Robert Mallet.pdf
 Filesize:  2.34 MB
 Downloaded:  461 Time(s)
