types of dampers in tall buildings?
vijaypatil
PostPosted: Thu Nov 29, 2012 10:56 am    Post subject: types of dampers in tall buildings? Reply with quote
Dear all,
Can anybody suggest the type of dampers for tall buildings. And how they helpful ?
Vijay R Patil
     This Message and its contents is intended solely for the addressee and is proprietary. Information in this mail is for L&T Business Usage only. Any Use to other than the addressee is misuse and infringement to Proprietorship of L&T Construction. If you are not the addressee please return the mail to the sender.
L&T Construction.
vijaypatil
PostPosted: Sat Dec 01, 2012 9:01 am    Post subject: types of dampers in tall buildings? Reply with quote
Vijay R Patil
L&T Construction.
thirumalaichettiar
PostPosted: Sat Dec 01, 2012 4:33 pm    Post subject: Reply with quote
Er.Vijay R Patil ,
Please find attached some pdfs in which some company catalogs and brouchers are attached. These will be explaining many technical notes.
In addition need to refer some good books already listed in the General discussion forum.
These catalogs are not an advertisement but to know further details more than in the test books.
T.RangaRajan.
Seismic Devices.pdf
 Filename:  Seismic Devices.pdf
 Filesize:  825.43 KB
 Downloaded:  612 Time(s)
GERB Spring Units.pdf
 Filename:  GERB Spring Units.pdf
 Filesize:  905.24 KB
 Downloaded:  702 Time(s)
fire protection for seismic isolation systems.pdf
 Filename:  fire protection for seismic isolation systems.pdf
 Filesize:  883.15 KB
 Downloaded:  597 Time(s)
fib Lead rubber bearings catalogue.pdf
 Filename:  fib Lead rubber bearings catalogue.pdf
 Filesize:  720.48 KB
 Downloaded:  648 Time(s)
ERADIQUAKE Isolation Bearings.pdf
 Filename:  ERADIQUAKE Isolation Bearings.pdf
 Filesize:  42.66 KB
 Downloaded:  517 Time(s)
eradiquake ISOLATION & FORCE CONTROL BEARING DEVICES.pdf
 Filename:  eradiquake ISOLATION & FORCE CONTROL BEARING DEVICES.pdf
 Filesize:  632.96 KB
 Downloaded:  855 Time(s)
PostPosted: Sat Dec 01, 2012 10:11 pm    Post subject: Re: types of dampers in tall buildings? Reply with quote
Dear Er Vijay,
The following two papers provide lot of info on Dampers:
Mitigation of motions of tall buildings with specific examples of Recent applications authored by Prof. Kareem et al. of the Univ. Of Notre Dame, published in Wind and structures, Vol. 2, No.3, 1999, pp. 201-251 is available at
http://www.nd.edu/~nathaz/journals/%281999%29Mitigation_of_motions_of_tall_buildings_with_specific_examples_of_recent_applications%28WAS%29.pdf
This paper also has a number of references.
Another recent and notable paper is by Symans et al. Energy Dissipation Systems for seismic applications: Current practice and Recent developments, Journal of Structural Engg., ASCE, Jan. 2008, pp.3-21. This paper also has numerous references.
http://www.taylordevices.com/Tech-Paper-archives/literature-pdf/92-EnergyDissipationSystems_SeismicApplications.pdf
Vijay R Patil
sureshkumar_kumaresan
E-Conference Resource
PostPosted: Sun Dec 02, 2012 3:13 pm    Post subject: Types of dampers in tall buildings Reply with quote
Dear Er. Vijay,
To my knowledge as far as controlling wind-induced response of buildings is concerned, the following dampers were used in the past: tuned mass damper (TMD), tuned liquid column damper (TLCD), tuned sloshing damper (TSD), Impact damper. For instance, Taipei 101 in Taiwan has Tuned Mass Damper at the top. Many buildings in New York are getting either TMD or TLCD/TSD. As far as I know we are yet to get a damper of this size in India, but soon some buildings in India will get dampers.
Suresh
