solution for undulation of flooring in ground Floor
Rajeev Mishra
PostPosted: Tue Feb 04, 2014 10:35 am    Post subject: solution for undulation of flooring in ground Floor Reply with quote
There is a problem in case of framed structure if a colony is constructed in Black Cotton soil having different slope. Generally plinth beam is casted 1.5 to 2.00 M above top of footing. Now what is the CHEAPEST way to do flooring i ground floor.
1. Simple flooring without any treatment below plinth beam.( In this case problem is that after some time Undulations occurred in floor as black cotton soil below floor goes out anywhere .)
SOLUTION - What is Cheapest solution- (I) I saw a building where they are casting RCC slab over PCC at ground level. I think it is costliest one . (II)Another solution is that prepare BOX by closing outer wall ( In a depth from bottom of plinth beam to lowest level of footing.) by brick masonry.(III) Do construct a basement but it is costly.
A request from all Engineers to suggest any other solution or comment in methods written above.
Rajeev Mishra
balki16
PostPosted: Thu Feb 06, 2014 8:54 am    Post subject: Reply with quote
Dear Sir
In the outer walls the beam should be be provided at 150 MM below the ground level (Grade Beam) so that wall can be constructed over the  grade beam to retain earth.
If black cotten soil is to be used for filfling it should be ensured that no water flows in to the plinth. (Bit difficult). Better used a better soil for filling under plinth.
K. B.
Rajeev Mishra
PostPosted: Thu Feb 06, 2014 9:18 am    Post subject: solution for undulation of flooring in ground Floor Reply with quote
I thank you for your valuable suggestions. Actually changes in the behavior of black cotton soil is occurred ,normally, up to 6' below GL. Hence level of grade beam should be around top of the footing 7 then plinth beam. A request from all engineers to comment. Rajeev Mishra.
umeshrao
PostPosted: Fri Feb 14, 2014 10:51 am    Post subject: Re: solution for undulation of flooring in ground Floor Reply with quote
Dear Mr. Rajeev Mishra,
Restricting myself to the flooring and not to others aspects mentioned in your mail, I think foremost thing take care of swelling of black cotton soil.
Hence, remove BC atleast upto 400 mm from natural ground level and do not use this soil as back fill. Fill this by any other soil containing about 60 to 70 % sand right upto bottom of PCC supporting floor finish. That is almost 400 + 300 = 700 mm of soil. One possible way is providing soling which has voids in rubble so that soil when expands can get into voids and not exert pressure on grade slab. Mixing lime in 1: 4 proportion is common practice to stabilize swelling soil.
If not provide structural slab connected to beams provided at plinth level and design for uplift due to swelling pressure.
Reducing cost keeping performance criteria is consider as economics.
Umesh Rao
