Very fundamantal question
kajal.chopra
PostPosted: Thu May 22, 2014 6:36 am    Post subject: Very fundamantal question Reply with quote
Hello,
Please see attached image
This problem is a pair of opposing shallow notches in a bar subject to tension. A linear elastic, plane strain idealisation is used
Using symmetry about a horizontal line gives the problem geometry shown in the attached figure.
The vertical line of symmetry is deliberately ignored - using it would force a corner node to be at the peak stress position which would be unrepresentative of most of the component features of interest.
However, if I analyse with the boundary conditions as shown in the attached figure (normal deflection along the 38.1 mm arrested- this is a symmetric bc) and distributed load of 100 MPa along the 9.525 mm edge, the analysis fails showing a singular matrix.
Can anyone please help
 Filesize:  7.22 KB
 Viewed:  322 Time(s)
vsmkumar
PostPosted: Thu May 22, 2014 2:44 pm    Post subject: Reply with quote
if you arrest  normal deflection along the 38.1 mm then it becomes a support.
you have to apply symmetric boundary condition option available in the software.
you are appealing plane strain condition means you are are assigning 0.0 to poissons ratio.
