Modelling of Active damper in SAP Etabs or Stadd pro
Post new topicReply to topic Thank Post    www.sefindia.org Forum Index -> Academic Project Guidance for B.Tech (B.E)/M.Tech (M.E)
jigar_mehta
PostPosted: Sat Nov 21, 2015 5:31 am    Post subject: Modelling of Active damper in SAP Etabs or Stadd pro Reply with quote
Respected Sir,
My topic for ME dissertation is comparision of siesmic analysis between actvie and passive damping system. In this project i will show time history analysis between active n passive dampers installed in a building of various heights. now the problem is how will i model active damper in softwares like sap, etabs or stadd pro.??
rahul.leslie
PostPosted: Tue Nov 24, 2015 10:15 am    Post subject: Reply with quote
Active and passive damping system? It's easy to do passive in SAP. But how active? In real buildings, you need a real time microprocessor (or computer) processing real time readings from accelerometers, and sending contolls to the active dampers - whether the damper is moving a TMD, or placed as diagonals in bays. You may use something like VHDL (or C) to program these microprocessors ( I don't know what they actually use).
In FE packages, you'll have to write a program taking in one data (accelerations), processing, and turning out the other (strain in damper). ANSYS has APDL, i believe it should do the trick. SAP also has a programming link (an API), which... i don't know much about. It might be able to be used for this.
Rahul Leslie
jigar_mehta
PostPosted: Tue Nov 24, 2015 10:25 am    Post subject: Reply with quote
Thank u so much for your guidance sir..
Post new topicReply to topic Thank Post    www.sefindia.org Forum Index -> Academic Project Guidance for B.Tech (B.E)/M.Tech (M.E) All times are GMT
