strap footing
binaya shahi
PostPosted: Tue Mar 22, 2016 4:44 am    Post subject: strap footing Reply with quote
strap beam is used to connect the eccentric footing of the exterior column on the property line to the adjacent interior column.
should strap beam be monolithic with the isolated footing to be strap footing.
can I cast the strap beam above the isolated footing such that there is a gap between isolated footing and strap beam?
sknsrinivasan
PostPosted: Tue Mar 22, 2016 5:05 am    Post subject: Reply with quote
Dear Binaya
  I have attached one pdf please Refer it
N.srinivasan
Strap Beam.pdf
 Filename:  Strap Beam.pdf
 Filesize:  139.84 KB
 Downloaded:  2044 Time(s)
binaya shahi
PostPosted: Mon Apr 11, 2016 2:31 pm    Post subject: Thank you! Reply with quote
sknsrinivasan wrote:
Dear Binaya
N.srinivasan
