suraj General Sponsor
Joined: 17 Apr 2008 Posts: 2312 Location: NCR Faridabad, E mail suraj_engineer@yahoo.co.uk
Posted: Tue May 31, 2016 8:56 am Post subject: Annex SL-IS 9001-2015 |
IS 9001-2015
Annex SL (replaces ISO guide)
Quality System
An organisation adopts a management system to take care of comfortably achieving its set objectives
Management system comprises various sets of procedures for charting out & implementing various operations or activities, so as to successfully reach its intended objectives,which leads to enhanced use of resources, improvement on risk management & increased customer satisfaction by meeting product or services expectations
Organizations do work on various management systems say Quality Management, Environment Management, Safety Management etc.
These various systems in line to ISO 9001-2008 used to work on varying management structures, causing inconvenience to interface with each other
Annex SL being a high level Management System has produced a common platform, so as all systems that organization adopts can be drawn, based on Annex SL designs orformat
Such arrangement provides many commonalities in designing system, implementation, monitoring, evaluation & improvement, by trying to eliminate conflicts that existed within ISO 9001-2008 system
All management systems shall have single high level identical core text, with common terms & definitions.
High level structure cannot be changed, but discipline specific sub clauses can beboth added or changed
Annex SL applies to all Management System standards, publically available specifications & technical specifications.
Revised ISO9001, 14001 & 45001 shall all be based on Annex SL high level structure
Annex SL structure isindicated below.................................................................................................................
IS 9001-AnnexSL.docx |
30.7 KB |
434 Time(s) |
_________________ Thanks & Warm Regards
Engineering & Arbitration
