beam column joint fixity
rangaraj21
PostPosted: Mon Feb 27, 2017 10:43 am    Post subject: beam column joint fixity Reply with quote
hi everyone:
  In analysis of RC framed structure (using any software), Is it reasonable to assume full fixity at beam column joints?
If yes
    how to achieve the same in field?
PostPosted: Mon Feb 27, 2017 6:21 pm    Post subject: Re: beam column joint fixity Reply with quote
Dear Er Rangaraj,
Since the columns and beams are cast monolithically in RC Construction, the assumption of rigid joints is valid. Moreover, the beam bars are usually made to go through the joint.
Semi-rigid joints are encountered in steel buildings only, that too when certain types of joints are considered.
rangaraj21 wrote:
hi everyone:
If yes
rangaraj21
PostPosted: Tue Feb 28, 2017 4:35 am    Post subject: Reply with quote
thank you sir
