Loft slab.
jain5489
PostPosted: Fri Mar 10, 2017 11:48 am    Post subject: Loft slab. Reply with quote
Dear,
I have one question that how can loft slab be designed.weather It is supported on Wall as cantilever or Making Beam on wall for support to cantilever type loft slab and Beam is supported on column. Please give some design for that.
Sasikumar Madakkannu
PostPosted: Fri Mar 10, 2017 4:30 pm    Post subject: Reply with quote
Loft Slab is a Cantilever Slab with span 1'-6"and it will come at Lintel Level. It is normally supported on the Lintel Beam when the structure is framed structure and it's supported on the wall when the structure is load bearing structure.
When we construct the Loft Slab for load bearing structure, remove the scaffolding of the loft slab after constructing the Floor / Roof Slab and wall above that Loft slab.
Sasikumar M.
