Tractive and Breaking force in Seismic Condition
swapnilgmc
PostPosted: Thu Mar 23, 2017 5:21 am    Post subject: Tractive and Breaking force in Seismic Condition Reply with quote
Dear Sir/madam,
While designing the Road/railway bridges in seismic condition, the effect of Breaking/Tractive effort shall be considered or not ? and where the codal provision is mentioned.
Kindly guide in this regards.
_________________
Thank you
bkballa
PostPosted: Wed Mar 29, 2017 8:34 am    Post subject: Reply with quote
Dear swapnilgmc,
Vehicle load need not be considered (or only 20% vehicle load need to be considered) when the direction of earthquake is in x-x direction (along the traffic). Hence, no need to include braking force (or only 20% braking load).
When earthquake is in y-y direction, I use to take all vehicle load and all braking load.
Hope this helps.
Biswa Balla
PS: Plz confirm whether no live load is taken or 20% is taken in EQxx.
swapnilgmc
PostPosted: Tue Apr 04, 2017 5:16 am    Post subject: Reply with quote
Thank u so much sir for your kind guidance
_________________
Thank you
msazarudhin
PostPosted: Wed May 10, 2017 11:13 am    Post subject: Reply with quote
As per (last) note in Clause 211.5 of IRC:6, "the structure under the fixed bearing shall be designed to withstand the full seismic and design braking/tractive force". And so the braking (not breaking ) force should be taken in seismic condition. i.e., braking force of 20% of vehicular load.
bkballa
PostPosted: Wed May 10, 2017 4:24 pm    Post subject: Reply with quote
msazarudhin
Posted: 10 May 2017 12:13    Post subject:
Dear msazaudhin,
You are right about the note on cl. 211.5 of IRC:6-2014. However in cl. 219.5.2 of IRC:6 states:
219.5.2 Live load components
i) The seismic force due to live load shall not be considered when acting in the direction of traffic, but shall be considered in the direction perpendicular to the traffic.
ii) The horizontal seismic force in the direction perpendicular to the traffic shall be calculated using 20 percent of live load (excluding impact factor).
This implies that you do not need to take braking/tractive force in case of EQxx (as no live load is present) and need to take 20% of braking/tractive force in case of EQyy.
,where EQxx = earthquake in x-x direction (ie direction of traffic); EQyy= earthquake in y-y direction (perpendicular to the traffic).
Is there something I missed regarding EQ and live load & braking force?
Biswa
msazarudhin
PostPosted: Thu May 11, 2017 4:44 am    Post subject: Reply with quote
Dear Biswa,
Your interpretation, "you do not need to take braking/tractive force in case of EQxx (as no live load is present) and need to take 20% of braking/tractive force in case of EQyy. " is not correct.
Clause 219.5.2  of IRC:6 depicts seismic force on live load need not to be taken when earthquake is in x-x direction. But (20%) live load is present in case of EQxx also.
So, braking force of 20% of Live load should be taken whether it may be EQxx or EQyy.
Greetings
Azarudeen.
