Limit state design IRC 112-2011 vs IS 456-2000
Post new topicReply to topic Thank Post    www.sefindia.org Forum Index -> Dams and Bridges
abhishek_ecs
PostPosted: Sun Dec 03, 2017 7:44 am    Post subject: Limit state design IRC 112-2011 vs IS 456-2000 Reply with quote
Hello ,
I was wondering since the stress strain diagram for concrete in both IRC 112and IS 456 is of rectangular parabolic type and stress strain diagram for steel is also similiar in IS 456 and IRC 112 (basic and seismic combination) , so the design for flexure and axial compression with bending should be similar in both cases.The difference I found was in design for shear ,torsion and punching shear.Also the checks for limit state of servicability is different in both codes. The design strain for steel in IRC 112 is 0.9∈yk while in is 456 it should be fy/1.15Es + 0.002 . But in SP105 (explaination to IRC 2011) worked out examples use the same method of calculating stress in reinforcement as IS 456 ,as in first calculating stress in extreme reinforcement according to design stress ie. 0.87fy and then using linear strain diagram to determine corresponding stresses in reinforcement in the interior of pier.
So the design for flexure and axial compression with bending should be similar in both cases, am i right?
Post new topicReply to topic Thank Post    www.sefindia.org Forum Index -> Dams and Bridges All times are GMT
