clause 8.1.3.3.3 (k) transfer structure
This forum is locked: you cannot post, reply to, or edit topics.This topic is locked: you cannot edit posts or make replies. Thank Post    www.sefindia.org Forum Index -> E-conference on IS 16700 13th March to 18th March 2018
hemalmistry
PostPosted: Wed Mar 14, 2018 7:45 pm    Post subject: clause 8.1.3.3.3 (k) transfer structure Reply with quote
For towers connected by common podium clause 8.1.3.3.3 (k) does not allow transfer structure at first connected floor. Does it mean that it can be provided at upper floors. IS 1893_1_2016 does not allow floating columns if thay are part of lateral load resisting system. Here if at upper floors transfer structures exists then it should be lateral load resisting or non lateral load resisting? Floating column as per IS 1893 and transfer structure as per IS 16700 shall be treated separately?
Table 12, describe the building as code exceeding building if it has transfer structure.
This forum is locked: you cannot post, reply to, or edit topics.This topic is locked: you cannot edit posts or make replies. Thank Post    www.sefindia.org Forum Index -> E-conference on IS 16700 13th March to 18th March 2018 All times are GMT
