When to use Passive pressure while desiging Cantilever Retaining Wall
Should Passive pressure be considered in the designing of Cantilever Retaining wall
Yes
0%
 0%  [ 0 ]
No
100%
 100%  [ 1 ]
Total Votes : 1
kawalbhatia
PostPosted: Mon May 14, 2018 10:19 am    Post subject: When to use Passive pressure while desiging Cantilever Retaining Wall Reply with quote
In the procedure of designing Cantilever Retaining wall, we calculate active and passive pressures which is acting on the structure. Active pressure is the pressure of earth fill which is to be retain at a certain height,and the second one is passive pressure. my doubt and question is
is there any specific condition when passive pressure is to be considered or not to be considered?
i have gone through many professional designs from several designers, some prefer not to consider passive pressure and they design for only active pressure, but some of the designers consider passive pressure in their designs even if there is no supporting earth at the location which counter balance the active earth pressure. Kindly explain the practical approach of considering the passive earth pressure.
My second point of issue is if angle of internal friction of soil is more than 30 degree then iam unable to get the value of active pressure coefficient (Ka) according to coulombs theory. Please help in getting the solution in this case?
_________________
KAWAL BHATIA
BRIDGE STRUCTURAL ENGINEER
RCSPL
durgaprasad
PostPosted: Mon May 14, 2018 12:12 pm    Post subject: Reply with quote
Dear Mr. Bhatia,
Passive pressure may be considered if face of stem, toe or shear key is being cast against undisturbed soil.
Now soil above toe is going to be disturbed during excavation or is a back filled soil hence passive pressure should not be considered.
Further if a designer is considering passive pressure for toe and shear key indication of where undisturbed soil is required should be clearly shown on drawing so that proper care may be taken during excavation.
Hope this explains the first query.
Best regards,
Durga Prasad Kulhari
