Structure engineer
Kumar Praveen
PostPosted: Thu Jun 14, 2018 5:25 pm    Post subject: Structure engineer Reply with quote
Dear sefian,
i need to make cut out in slab of size 450*600mm for passing AHU pipe line. Problem is that slab is casted to 130mm in thickness and  there is not any provision of cut out while casting/planning. Can i make cut out in slab and what will be the Precaution to insure At site .
PostPosted: Fri Jun 15, 2018 3:38 pm    Post subject: Re: Structure engineer Reply with quote
Dear Er Kumar,
This is a practical problem and requires expertise and more details. If this is a new slab, additional reinforcements are necessary around the opening as shown in Fig. 10.53 (Example 10.10) of my RC design book (Oxford Univ. Press, 2013).
But you are going to cut an existing slab. It may be necessary to strengthen the slab around openings.
The most used method for increasing the moment capacity is to addsteel or FRPComposites plates to the surface of a slab, connected with the help of bolts or post-installedanchors. Although the installation of the steel plates is rather easy ithas to be considered that it must not interfere with the flooring system. Whenusing bolts for connecting the plates, they interfere with the flooring system.Normally the plates are installed on the bottom of the slab with post-installedanchors. A disadvantage of this method is that overlapping is difficult, thus itworks best when strengthening is required in only one direction.  See Example 5.6 of my RC design book for the calculations involved.
Anyway please also check whether strengthening is required. You have not informed the type of slab(one way, two way or flat slab), size of slab, where the cut out is made(near supports, mid span etc).
Kumar Praveen wrote:
Dear sefian,
sktrisal
PostPosted: Fri Jun 15, 2018 4:30 pm    Post subject: Structure engineer Reply with quote
location of the cutout shall determine the strengthening proceduressktrisal
On Fri, 15 Jun 2018, 12:01 Dr. N. Subramanian, <forum@sefindia.org (forum@sefindia.org)> wrote:
           Dear Er Kumar,
      Kumar Praveen wrote:                Dear sefian,
Naveen CHIPPAGIRI
PostPosted: Fri Jun 15, 2018 6:30 pm    Post subject: Structure engineer Reply with quote
Respected sir Im intrested in doing job in construction
Would u please refer me to ur known companies thankq sir
On Jun 15, 2018 9:31 PM, "Dr. N. Subramanian" <forum@sefindia.org (forum@sefindia.org)> wrote:
           Dear Er Kumar,
final_resume_fresh_.pdf
 Filename:  final_resume_fresh_.pdf
 Filesize:  209.89 KB
 Downloaded:  118 Time(s)
deepesh songara
PostPosted: Fri Jun 15, 2018 8:30 pm    Post subject: Structure engineer Reply with quote
Hello sir , may i ask questions ?
Deepesh Songara
Civil EngineerMobile: +918826882840Email: deepesh.songara04@gmail.com (deepesh.songara04@gmail.com)
On Fri, Jun 15, 2018 at 9:08 PM, Dr. N. Subramanian <forum@sefindia.org (forum@sefindia.org)> wrote:
           Dear Er Kumar,
Kumar Praveen
PostPosted: Sat Jun 16, 2018 8:50 am    Post subject: Repected N.S sir. Reply with quote
Repected N.S sir.
Sir i seen the diagrame you suggested , i feel  this diagram is useful  before casting of slab.  But my problem is that, slab is casted at site. After casting of few days HVAC  consultant suggested the place of AHU and duct for services.
Following information regarding slab 1. Slab is two way slab
2. Some Duct are coming near to end and some are far from end
3. Some of Duct are coming nearer to each other
4. diagram and place are located in attached file
plz see.
Kumar Praveen
PostPosted: Sat Jun 16, 2018 9:50 am    Post subject: dear sir, Reply with quote
i attached a file showing location of duct
slab cut out
 Filesize:  180.82 KB
 Viewed:  160 Time(s)
sankar
PostPosted: Mon Jun 18, 2018 12:30 pm    Post subject: Structure engineer Reply with quote
Dear Dr. NS,
For two-way strengthening requirement, use of Carbon Fiber sheet may be thought of by providing it in two directions under the slab by the sides of opening.
Fixing of carbon fiber in place is easy with epoxy based adhesive. Only, UV resistant coat may have to be applied on carbon fiber if exposed to sunlight.
Your views, please.
Sankar Chakraborty
--Original Message--
From: Dr. N. Subramanian [mailto:forum@sefindia.org]
Sent: Friday, June 15, 2018 9:08 PM
To: general@sefindia.org
Subject: [SEFI] Re: Structure engineer
Dear Er Kumar,
Dear sefian,
"Confidentiality Warning: This message and any attachments are intended only for the use of the intended recipient(s).
are confidential and may be privileged. If you are not the intended recipient. you are hereby notified that any
review. re-transmission. conversion to hard copy. copying. circulation or other use of this message and any attachments is
strictly prohibited. If you are not the intended recipient. please notify the sender immediately by return email.
and delete this message and any attachments from your system.
Virus Warning: Although the company has taken reasonable precautions to ensure no viruses are present in this email.
The company cannot accept responsibility for any loss or damage arising from the use of this email or attachment."
