Excel Sheet for ETABS Import
sagarvk
PostPosted: Wed Jul 18, 2018 4:38 am    Post subject: Excel Sheet for ETABS Import Reply with quote
I have attached a Excel file which imports Beam Moments for all the beams of a ETABS model with selection criteria as maximum positive and maximum negative moments comparing with moments of all the Load Combinations and calculating the required Ast. It is still in development phase and would like suggestions on it to make it more compatible.
Steps for using the Sheet are as follows.
1. Analyze the structure in ETABS.
2. Open the Excel file and click interact and click on Open ETABS button. (Note - Please use a copy of ETABS file and not original file for safety. Also change the date if etabs gives an license error on crack versions.)
3. After ETABS is opened, open the project file and after it is opened, minimize the ETABS and again switch to Excel file. (Note - Please use a copy of ETABS project file and not original file or please take a backup of your project file for safety.)
4. In Excel, click Get Beam Reactions button and wait for the message of Successful import.
5. Click on Calculate Ast and after success, click on close ETABS button to close it.
Currently this file is been programmed to work with ETABS 2015 version only and will add a file for 2016 version soon.
Please note that this Sheet is in development phase, also please suggest your views and changes to be done.
Beam Reactions.zip
 Filename:  Beam Reactions.zip
 Filesize:  90.53 KB
 Downloaded:  154 Time(s)
Katore Sagar V.
saikiran gone
PostPosted: Thu Jul 19, 2018 6:33 am    Post subject: Re: Excel Sheet for ETABS Import Reply with quote
Hi,
First off all I shall appreciate your work , I am getting the compile error when clicking the interact button, please check the image attached for your clear understanding.
With Cheer,
Saikiran Gone.
 Filesize:  393.76 KB
 Viewed:  60 Time(s)
sagarvk
PostPosted: Thu Jul 19, 2018 6:47 am    Post subject: Re: Excel Sheet for ETABS Import Reply with quote
Hi,
With Cheer,
Saikiran Gone.
Currently this version works on for ETABS 2015. Can you pls pm me your ETABS application path, I will change the code and upload the file by making changes.
Katore Sagar V.
