ykalamkar ...
Posted: Mon Nov 05, 2018 8:45 am Post subject: |
We can model the shear wall as column having same size as we are providing... |
Posted: Fri Nov 16, 2018 10:47 pm Post subject: |
ykalamkar wrote: | We can model the shear wall as column having same size as we are providing... |
Dear Er Kalamkar
NO. It is because the purpose and the behaviour of shear wall and column are completely different
NS |
aditya ...
Posted: Sat Nov 17, 2018 4:19 am Post subject: |
Dear Respected Dr. N. Subramanian Sir,
Could you please throw some light on how to design boundary elements of a RC Shear Wall as per IS 13920: 2016 clause 10.3.1?
with regards,
Aditya
Posted: Sat Nov 17, 2018 5:16 am Post subject: |
Dear Er Aditya
I think you asked the question a few days ago also. As I have not looked into that code I did not reply. I think the new code says that the expressions given in Annex A are not applicable for shear walls with boundary elements. May be ACI 318 has solution! I need to Check
aditya wrote: | Dear Respected Dr. N. Subramanian Sir,
with regards,
Aditya
avnishpoddar88 SEFI Member
jagan0819 ...
Posted: Fri Nov 30, 2018 5:24 am Post subject: Re: You can easily do SHEAR WALL Design in STAAD/PRO. |
Dear Pandya Sir,
As informed by you through earlier posting on the topic, would you please mail me the copy of the staad file "shear.std" (Shear Wall FRAME Interaction Model) to the following mail address for learning shear wall design in staad?
jagan0819@gmail.com
regards |
Nilanjansamant General Sponsor
Posted: Fri Jan 11, 2019 3:23 am Post subject: staad shear wall file |
Respected V Pandya sir,
with due respect, i would like to inform you could you please send me the bellow mentioned file
1) EXAMP09.std. Example 9 (U.S. Example)
2) Shearwall.std. Shear Wall FRAME Interaction Model
my email id is nilanjan.civil@gmail.com
jagan0819 ...
Posted: Fri Jan 11, 2019 4:42 pm Post subject: Re: You can easily do SHEAR WALL Design in STAAD/PRO. |
sir pls send staad file for me also
email-jagan0819@gmail.com
regards |
VPandya General Sponsor
Posted: Sat Jan 12, 2019 5:41 am Post subject: Re: staad shear wall file |
Er. Nilanjan ,
I send you the STAAD Shear wall files . Could you send these to Er. Jagan . I have some problems with his E-Mail address on my computer .
Vasudeo Pandya P.E.
Structural Engineer
Nilanjansamant wrote: | Respected V Pandya sir,
Posted: Sun Jan 13, 2019 3:34 pm Post subject: staad shear wall file |
Respected V Pandya sir, with due respect i would like to thank you cordially. i have sent Staad file of shear wall as per your instruction. Sir some years ago you taught me in SEFI fixed base and hinge base structure for steel structures and you said that soil structure interaction is the actual solution. Therefore i would like to request you , could you please send me the Staad file of soil structure interaction model. your's truly, Nilanjan Samanta |
