Shear wall design in a multi storied building
Post new topicReply to topic Thank Post    www.sefindia.org Forum Index -> Academic Project Guidance for B.Tech (B.E)/M.Tech (M.E)
meerameen
PostPosted: Thu Aug 11, 2016 4:16 am    Post subject: Shear wall design in a multi storied building Reply with quote
Dear sir,
                I have to design a ahear wall in staad pro. Since shear wall is continous from foundation to roof . How can i model it in staad without floor beams in the middle.
Kindly suggest.
syed_A
PostPosted: Thu Aug 11, 2016 11:15 am    Post subject: Reply with quote
Post your model sketch to have an idea / understand easily
meerameen
PostPosted: Thu Aug 11, 2016 11:40 am    Post subject: Shear wall design in a multi storied building Reply with quote
Sir,
Kindly find the plan picture of the project.its a g+7 storey building. Assume all beams and columns are same size. And slan 125 mm thick. Shearwall 250 mm.
Total 8 shear walls. 4 at the coners . 2.5m each and 4 at staircase  1.235m each. Hw should i model this plan. Since shearwall is through wall from basement to roof. No beam comes above it in each floor level. I have watched videos in which beam is placed above shearwall at floor level.i think its a wrong practise.
syed_A
PostPosted: Thu Aug 11, 2016 4:59 pm    Post subject: Reply with quote
Dear Engineer
First model the structure as per your requirement/dimensions
Then add shear wall at four corners using surface elements  and also for staircase area. Select all the beams by switching to front view,add auto generation of plates as slab with required thickness
lastly delete the columns/beams where ever your shear wall presents
Use translation command to generate number of floors
Finally assign properties,supports,loads , analysis and design command with necessary parameters...Done
I cannot say about those  shear wall tutorials, whether correct or wrong
good luck
podianu1
PostPosted: Wed Dec 12, 2018 8:56 am    Post subject: Reply with quote
Do you need shear walls, rather than straight away giving them, examine if its required, in fact suggest  you increase the thickness of component members for economy.
Post new topicReply to topic Thank Post    www.sefindia.org Forum Index -> Academic Project Guidance for B.Tech (B.E)/M.Tech (M.E) All times are GMT
