Need of Detailing Awareness For Safe Structures
Goto page Previous  1, 2, 3 ... , 29, 30, 31  Next
PushkarKokane
PostPosted: Fri Dec 22, 2017 9:44 am    Post subject: Footing Reply with quote
Respected Sir
is pedestal necessary?
PostPosted: Fri Dec 22, 2017 1:32 pm    Post subject: Re: Footing Reply with quote
PushkarKokane wrote:
Respected Sir
Dear Er. Pushkar
Pedestal is usually provided in steel structures. Sometimes a designer may provide a pedestal to decrease the depth of footing, as the cantilever depth of footing may be reduced.
ozzfan
PostPosted: Tue Dec 26, 2017 2:12 am    Post subject: Reply with quote
B.V.Harsoda wrote:
Very Useful Literature with good detailing of Confined Masonry  From IIT Gandhinagar
Link:-
https://www.iitgn.ac.in/sites/default/files/ConfinedMasonry.pdf
Thank you very much Sir, this is really very useful.
B.V.Harsoda
Bronze Sponsor
Bronze Sponsor
PostPosted: Sun Jan 14, 2018 5:00 am    Post subject: Reply with quote
Bridge detailing Guide:-
https://ftp.dot.state.tx.us/pub/txdot-info/brg/design/bridge-detailing-guide.pdf
B.V.Harsoda
Bronze Sponsor
Bronze Sponsor
PostPosted: Thu Jan 18, 2018 4:48 am    Post subject: Reply with quote
B.V.Harsoda
Bronze Sponsor
Bronze Sponsor
PostPosted: Sun Feb 04, 2018 5:36 am    Post subject: Reply with quote
Very informative  & useful link for Detailing:
http://www.buildinghow.com/en-us/Products/Books/Volume-A/The-reinforcement-I/Shear-walls/Anchoring
 Filesize:  152.89 KB
 Viewed:  118 Time(s)
PushkarKokane
PostPosted: Fri Feb 09, 2018 6:29 pm    Post subject: Reply with quote
Sir.
Some time in structure first wall construct and than column and beam cast. any effect on column Beam structure of after constructed wall or before wall.
B.V.Harsoda
Bronze Sponsor
Bronze Sponsor
PostPosted: Sat Feb 10, 2018 4:30 am    Post subject: Reply with quote
Dear Er.
       If in R. C. C. Framed structure, wall constructed first and concreting done after, then this structure  will act as  composite monolithic constructed  structure of  R. C. C. & Masonry. Transformed Moment of Inertia of equivalent area of steel, concrete and masonry  is too much higher than MI of  RCC beam. As per my personal opinion it may not be any adverse effect on structural strength of such monolithic composite structure in which  masonry (Brick masonry  or Higher strength masonry than brick masonry) constructed first and after some time column and beam concreting carry out. Earthquake resistance may be more of such composite structure.  As this  is my individual thinking, it is  requested to all Experts of this forum to Discuss & give their opinion in this topic and correct me if my thinking is require any improvement.
To understand transformed section below link may be useful to you
Transformed section:
http://www.nptel.ac.in/courses/105106117/pdf/9_Special_Topics/Section9.1.pdf
Transformed Area Method for Composite Beams - Mechanics of Materials:
https://www.youtube.com/watch?v=G5vBOzMu6P0
Best Wishes,
Er. B. V. Harsoda
Sir.
B.V.Harsoda
Bronze Sponsor
Bronze Sponsor
PostPosted: Tue Feb 13, 2018 1:55 pm    Post subject: Reply with quote
Useful  Columns & Footings strengthening photographs showing good detailing of reinforcement by Er. Ishwar:
https://www.sefindia.org/forum/viewtopic.php?p=78702#78702
saudgokul
PostPosted: Mon May 06, 2019 6:58 am    Post subject: Photographs Needed Reply with quote
thirumalaichettiar wrote:
In continuation of my previous posting pl.find below detailed drawing for a 2-way slab including the details for torsion as found in the reference noted in the JOG format.
Can any sefians report that he makes and follows this detail for slab against the conventional bent up bars? It takes a bit long time to prepare the details but at construction site it requires less labour and less wastage of bar. Nowadays I am preparing and giving to the clients.
T.RangaRajan.
Thank you for your information. It is really helpful. I want to see the photograph of a real site where this system of detailing has been followed. Especially, the torsional reinforcement part. I want to know that if both flexural reinforcement and torsional reinforcement are provided together or the locations where the torsional reinforcement is provided, flexural reinforcement is not provided.
Page 30 of 31
