Temperature Load in Delhi for a Slab without expansion Joint and its load combination
middlespan
PostPosted: Thu Jul 11, 2019 7:05 am    Post subject: Temperature Load in Delhi for a Slab without expansion Joint and its load combination Reply with quote
Dear Sir,<o></o>
               With reference toIS 875 part 5 1987 fig 1 and 2 gives the maximum and minimum temperature of47.5 deg C and -2.5 deg C which gives the difference of 50 deg C .<o></o>
Should we apply this temperature difference of 50 deg during analysis indesign softwares like Etabs . If a reduced temoerature difference is suggestedwhat is the supporting codal reference to substantiate the same . <o></o>
Also As per IS 875 part 5 cl.8 mentiones only service combination of1DL+1LL+*1Temp whereas ACI has ultimate combination of 1.2DL+1.6LL+-1.2Temp .<o></o>
Is there a mention of Ultimate combination of temperature load in IndianStandards.<o></o>
Thanks in advance
.<o></o>
Engineer Nichkil
