rajesh_reddy SEFI Member
Posted: Mon Aug 05, 2019 7:08 am Post subject: Formwork Design |
For the design of temporary formwork for deck slab should we consider Earthquake Loads, if to be considered please provide with some literature as per IRC standerds.
Description
For Flyover 6 x 40m span with Steel Composite Girder, Formwork to be designed for Concrete Deck Slab. This Flyover is located in Zone V, Substructure construction is done and Steel Girders are also placed in position.
Falsework items used are Plywood, Wooden Runners, ISMC, Acrow span, ISMB, Vertical Cuplocks, MS Cribs.
with regards,
K Rajesh. |
