PEB design
Goto page Previous  1, 2, 3
Salman Alibhai Dhroj
PostPosted: Fri Sep 13, 2019 9:19 am    Post subject: Reply with quote
ashisheck wrote:
Dear sir
i have a work of foundation design of  semi peb structure
where reaction is
Load & Load comb. Fx kN Fy kN FZ KN moment at bottom of column (col.ht.=5m)
DL+LL 36.8 15.52 184
DL+wlx(sc) -108.5 -41 -542.5
DL+wlx(Pr) -141.5 -67 -707.5
DL-wlx(Sc) -101.5 -39 -507.5
DL-wlx(Pr) -138.5 -45 -692.5
DL+wlz(Sc) -87.5 -37 -437.5
DL+wlz(Pr) -162.5 -67 -812.5
DL-wlz(Sc) 35.5 15 177.5
DL-wlz(Pr) 35.5 15 177.5
this is at +5m. from ground. and after peb structure is rested on 5m length of RCC column
so column and foundation has a vary high moment
just in dl+wlz(pr) is 812.5 so i will design foundation in such heavy moment case.........
Thanks in advance
sandeep_chauhan wrote:
Some leading PEB manufacturers in the world with there web addresses are there in the link below.
http://www.mbsweb.com/htmls/clients%202.htm
Hope it will help.
Sandeep Chauhan
Sr-Engineer (PEB Design)
mjnasar
PostPosted: Wed Sep 18, 2019 12:27 pm    Post subject: Reply with quote
Dear Engineer
I suppose the tie beams, framings & cross ties at the
level of bottom of steel or
level of grade beam
will reduce / balance moments.
-Try as 3d frames at level of footings, level of grade beams etc.
Page 3 of 3
