irfan_shaik SEFI Member
Posted: Mon Oct 14, 2019 4:18 pm Post subject: COLUMNS MISPLACED |
DEAR SEFIANS,
Hi my name is IRFAN SHAIK iam constructing 2BHK in 660sq.ft Site dimensions are 30'x22' while marking 3 columns misplaced now construction is in plinth level can any body guide me what can I do at this stage iamuploading the pics and my plan
197.64 KB |
Viewed: |
306 Time(s) |
191.16 KB |
Viewed: |
311 Time(s) |
182.29 KB |
Viewed: |
306 Time(s) |
GF PLAN.pdf |
158.51 KB |
507 Time(s) |
syed_A ...
Posted: Mon Oct 14, 2019 6:42 pm Post subject: |
Dear Mr Irfan Shaik
Bending the column bars to rectify the misplaced one is not the solution
Provide the column beam framing drawing so that a proper solution/rectification can be discussed
reagrds
es_jayakumar General Sponsor
Posted: Tue Oct 15, 2019 2:03 pm Post subject: |
If a horizontal bend, as done by you, is introduced in a column, that stretch will act as a cantilever beam and the steel provided for the column will not be sufficient to take care of the BM so developed. You can modify your grid pattern to get over the glitch.
mjnasar ...
Posted: Wed Nov 06, 2019 1:40 pm Post subject: |
Dear Engineer
Please see the attached sketch it might help you
108.7 KB |
Viewed: |
265 Time(s) |
ShiftingColumn_006Nov19.pdf |
20.29 KB |
423 Time(s) |
spsvasan ...
Posted: Sun Nov 17, 2019 5:16 am Post subject: |
es_jayakumar wrote: | If a horizontal bend, as done by you, is introduced in a column, that stretch will act as a cantilever beam and the steel provided for the column will not be sufficient to take care of the BM so developed. You can modify your grid pattern to get over the glitch.
E S Jayakumar |
Dear Er.Irfan Sheikh
I agree with Er.Jayakumar. The present condition will result in unsafe structure. Column may be taken vertically and the grid pattern may be altered
S.P.Srinivasan
Posted: Mon Feb 10, 2020 12:25 pm Post subject: |
Er.irfan_shaik,
As Er.Jeyakumar and Er.Sp.Srinivasan suggested it is not advisable to bend the column bars.
My suggestion id keep the column bars and live with the same location withour any kinks or bending and try to reanalysis the framing that is the beams according to the column position.
As Er.syed_A informed attach the drawing showing the exact present location so that u will get a good suggestion from others.
T.Rangarajan
