connection of columns at plinth level and floor level with beams
jagan0819
Progressive Member
Progressive Member
PostPosted: Wed Feb 26, 2020 10:28 am    Post subject: connection of columns at plinth level and floor level with beams Reply with quote
hi sefians
i have a doubt in modelling of a structure(G+1) in staad ,i.e should all the columns at plinth level and floor level(in both directions) get connected with beams. if yes is there any specific reason behind that and if no is there any parameter in staad that we should provide.
image was attached( PLS OBSERVE C14,C15,C16 )
 Filesize:  106.92 KB
 Viewed:  23 Time(s)
sukanta.adhikari
PostPosted: Thu Feb 27, 2020 4:32 am    Post subject: Re: connection of columns at plinth level and floor level with beams Reply with quote
It is a good practice to connect the all the columns together.As per older version of IS 1893(You can check the new one)
7.12.4 Connections Between PartsAll parts of the building, except between the separationsections, shall be tied together to act as integratedsingle unit. All connections between different parts,such as beams to columns and columns to theirfootings, should be made capable of transmittinga force, in all possible directions, of magnitude( Qi/wi) times but not less t&m 0.05 times the weightof the smaller part or the total of dead and imposedload reaction. Frictional resistance shall not be reliedupon for fulfilling these requirements.
If there is no restriction connect all the columns.But practically it is not possible always...sometimes in Industrial building/structure we are not able to connect columns in all direction.The layout is such that  pipe trench,cable trench,equipment foundation comes in between..and we can't convince the technical person of other discipline nor the client to change equipment disposition/trench etc..So in that case you can use ELX and ELy parameter in staad.
Here is the link to use it
https://www.sefindia.org/forum/viewtopic.php?t=14625
In your case it seems that there is no restriction,so it is better you provide it ..Since the columns are tied in the direction of major axis and not in minor axis.
S adhikari
jagan0819 wrote:
hi sefians
syed_A
PostPosted: Thu Feb 27, 2020 5:27 am    Post subject: Reply with quote
Engr S adhikari
Since the plinth beam rest on ground, Do we need to consider  support conditions in staadpro or simply model it as any other beam which supports slab, wall etc
