kawshik9 General Sponsor
Posted: Sun Mar 15, 2020 5:59 am Post subject: Wind load calculation on pitched roofs of buildings |
Dear SEFIians,
I have doubt in calculating wind load on pitched roofs of buildings, Kindly clarify my doubt.
As per Table 5 of IS 875 part-3, For wind in 90 degrees direction, Cpe coefficients are given for EG & FH regions. EG region corresponds to L/4 length of building and FH region to another L/4 length. What about another L/2 length of the building on lee ward side ? What force we should consider for another L/2 length of building in leeward side? or We need not take an wind load for this region.
Thanks and regards,
Ramakanth
es_jayakumar General Sponsor
Posted: Fri Mar 27, 2020 1:59 am Post subject: |
In this case, you consider the wind is blowing in the reverse direction at θ = -900,ie, from bottom to top on plan. Then you can make use of the same Cpe coefficients as for EF & GH, for the bottom 2 segments each of L/4 length, in a mirror image fashion.
Posted: Wed Apr 08, 2020 1:14 am Post subject: |
Dear Er.kawshik9,
Please refer the attached PDF file for your reference. I may add more after going through my files.
Thanks,
T.RangaRajan.
Cpe VALUE FOR TRUSS ROOF.pdf |
285.06 KB |
402 Time(s) |
INTERNAL PRESSURE AS PER IS CODE.pdf |
152.83 KB |
415 Time(s) |
EXAMPLE ROOF WIND LOAD AS PER IS 875-3.pdf |
290.06 KB |
1891 Time(s) |
