sathyace ...
Posted: Mon Feb 24, 2020 11:50 pm Post subject: Staircase support at first floor level |
Hi All,
Please refer the attached file and guide me what is the best way to provide support for the staircase?
Thanks,
Sathya.
18.42 KB |
Viewed: |
326 Time(s) |
syed_A ...
Posted: Tue Feb 25, 2020 6:06 am Post subject: |
Dear Engr
Shift or provide this column and extend the beam as cantilever upto the width of waist slab so that you rest the flight on this beam (refer attach image ), provided if it is possible as per the requirement and working architectural plan. I doubt about the next flight from FF slab?
14.96 KB |
Viewed: |
277 Time(s) |
Posted: Wed Apr 08, 2020 3:06 am Post subject: |
Dear Er.Sathyace,
Please note that the staircase is an inclined slab which will produce horizontal force as in arches. If you miss or unnoticed to provide a support beam it can be done by laying a floor slab to about 3' length of stair width with bare min steel reinforcement connecting the staircase reinforcement.
This way you can provide details.
If this is not clear I can send a sketch.
sathyace ...
Posted: Fri Apr 10, 2020 2:00 am Post subject: |
Thank you Sir,
Please provide me sketch for clear understanding.
Sathya.
Posted: Sun Apr 12, 2020 1:59 pm Post subject: |
Dr.Sathyace,
Please find the sketch showing the details for the staircase support at GROUND floor level. The 4' width can be reduced to 3'-0".
Need to know whether you use this detail and if used if there is any problem let me know. I used this type of support in many occasion but face no problem.
T.RangaRajan
STAIRCASE BOTTOM SUPPORT AT FLOOR LEVEL.pdf |
120.85 KB |
520 Time(s) |
