badamsundararao ...
Joined: 24 Dec 2009 Posts: 213 Location: KAKINADA ANDHRA PRADESH
Posted: Wed Apr 08, 2020 2:26 pm Post subject: CIRCULAR COLUMN V/S SQUARE COLUMN. |
for most of Bridge piers generally Circular columns will be used because of Symmetrical axis of the Column and to have good ambience and maneuverability. |
sathyace ...
Posted: Thu Apr 09, 2020 1:16 am Post subject: |
Thank you Sir.
If we take same size of square and circular section to carry some load say 'X' kN,which one will have the more load carrying capacity? |
badamsundararao ...
Posted: Thu Apr 09, 2020 2:37 am Post subject: CIRCULAR COLUMN |
Definitely Square column will carry more load. |
rajancivildesign@gmail.co ...
Posted: Thu Apr 09, 2020 3:21 am Post subject: Circular column in bridge design |
For bridge design across river course, circular column is provided to divert waterway suitably in the upstream and downstream. For bridges in city like metro you can see only square column. Circular column will take more load only in case of helical ties. But in practice only circular rings are provided as column ties. Based on area of column and reinforcement provided the column with take appropriate loads.
V. M. Rajan |
sathyace ...
Posted: Fri Apr 10, 2020 5:59 pm Post subject: |
Thank you Rajan Sir,
Circular columns(piers)are used in bridges in metro cities since it reduces the water impact pressure on columns and also due to its symmetrical axis it has better load transfer capacity.
Please provide you suggestions.
Sathya. |
