Help me with Floating Column
PostPosted: Thu Jul 16, 2020 7:01 pm    Post subject: Re: A .pdf copy of ASCE Failure Case Studies is attached Reply with quote
Thank you Er Pandiyaji
See also this that happened in Bihar within a few days of its inauguration!
https://timesofindia.indiatimes.com/city/patna/erosion-of-approach-road-disrupts-traffic-on-sattarghat-overbridge/articleshow/76987281.cms
Warm regards
VPandya wrote:
Dear  Dr. Subramanian,
Thanks.  Certainly .
I am attaching a . pdf  copy of  " FAILURE  CASE STUDIES IN CIVIL ENGINEEEING " 2nd Ed, "
I hope it is O.K. to break ASCE rule to use this publication for personal use . SEFI is used also for mentoring/educating  young Structural Engineers .
Vasudeo Pandya  P.E.
Structural Engineer
VPandya
PostPosted: Fri Jul 17, 2020 4:33 am    Post subject: Very sad condition in this photo you attached . Ned to do a better job. Reply with quote
Dr.  Subramanianji
Very sad condition in this photo you attached . Need to do a better job.
In SEFI we have discussed quite a bit about PROOF CHECKING by THIRD PARTY .
After some major Structural failures in some cities of USA , now the city building Departments  requires a PEER REVIEW ( PROOF CHECKING ) by third party , before they issue a CONSTRUCTION PERMIT .
Need to do something than to see photo you attached .
Vasudeo Pandya P.E.
Structural Engineer
IAStrcutE_Proof Checking-1.pdf
PROOF CHECKING document from IAStructE, not a full document
 Filename:  IAStrcutE_Proof Checking-1.pdf
 Filesize:  461.02 KB
 Downloaded:  59 Time(s)
sakumar79
PostPosted: Fri Jul 24, 2020 4:37 am    Post subject: Reply with quote
   One possibility is to remove C5 in all floors and have the beam from C1 to C9 as single continuous span on which the central beam will rest. That beam can be either along C9 and C14 or along C1 alignment. This way you can avoid the column in all floors. However, that long beam will be quite heavy and will also transfer some considerable moments to C1/C9 which has to be considered suitably in the design.
Hope that helps
Arun
