velrajkumar.g SEFI Regulars
Posted: Fri Jul 24, 2020 9:54 am Post subject: Dimension of Standard steel- Reg |
Where we measure the thickness of flange of I beam and design which one we take for outer edge or inner edge of flange
Last edited by velrajkumar.g on Sun Jul 26, 2020 8:11 am; edited 1 time in total |
Posted: Sat Jul 25, 2020 1:08 am Post subject: Re: Dimension of Standard steel- Reg |
Dear Er Velrajkumar
You need to ask your supplier about this!
velrajkumar.g wrote: | Dear sir,
I was purchased rolled steel I section from local market in Coimbatore,India, Dimension of section as follows
Overall depth of section is 125 mm, Width of section is 65mm,Thickness of flange and web is 5mm.
As per steel table, thickness of flange and web for rolledsection is not same.
Why the thickness of flange and web is not same.
Velrajkumar |
es_jayakumar General Sponsor
Posted: Sun Jul 26, 2020 12:11 pm Post subject: |
Can it be due to the fact that the local re-rolling mills are making the structural steel sections without any reference to the Standards ?
E S Jayakumar |
rsharma SEFI Member
Posted: Mon Jul 27, 2020 8:30 am Post subject: Dimension of Standard steel- Reg |
Check if product has IS mark?If yes, you can also complain to BIS.
Sent from Yahoo Mail on Android
