staad pro fixed but support
Goto page Previous  1, 2, 3  Next
sknsrinivasan
PostPosted: Sat Oct 31, 2020 5:07 pm    Post subject: Reply with quote
You didn't  reply, no problem. if you want drawing for every thing not possible you have to try answer what people asking try to understand me If you are feeling  any thing  wrong sorry
PostPosted: Sun Nov 01, 2020 2:29 am    Post subject: Reply with quote
Sorry.
Please see this sketch.
I hope this is what you are looking for. Otherwise, please specify.
ES Jayakumar
 Filesize:  1.46 MB
 Viewed:  34 Time(s)
sknsrinivasan
PostPosted: Sun Nov 01, 2020 3:37 am    Post subject: Reply with quote
Yes correct in this one  the roller  is vertical I want another one if the roller  is Horizontal  Thank you very much For Your Sketch Sorry  For Distribuing You before doing any thing I would like to discuss  with well known person like you
VPandya
PostPosted: Sun Nov 01, 2020 3:44 am    Post subject: IF ON THE COLUMN WITH BOTTOM SUPPORT ROLLER , TOP CAN NOT BE ROLLER Reply with quote
Dear Sefi friend ,
IF ON THE COLUMN WITH BOTTOM SUPPORT ROLLER , TOP CAN NOT BE ON  THE ROLLER OR SYSTEM IS UNSTABLE .  IS THIS FRAME IS THE ONLY FRAME ?  YOU NEED SOME OTHER FRAME TO MAKE THE SYSTEM STABLE .  LATERAL STIFFENESS OF THE SYSTEM IS IN QUESTION ? .  STAAD WILL NOT RUN AND WILL GIVE AN ERROR MESSAGE  SAYING YOUR SYSTEM IS UBSTABLE .
Vasudeo Pandya  P.E.
Structural Engineer
sknsrinivasan
PostPosted: Sun Nov 01, 2020 3:52 am    Post subject: Reply with quote
Dear pandya sir
  I know that one here I have asked  understanding of the software
VPandya
PostPosted: Sun Nov 01, 2020 3:56 am    Post subject: Reply with quote
sknsrinivasan wrote:
Dear pandya sir
O. K.
Pandya
sknsrinivasan
PostPosted: Sun Nov 01, 2020 4:04 am    Post subject: Reply with quote
Dear pandya sir
  I  would like to ask you another  question In substitute  Frame Bottom Portion Of Column Fixed Top Portion Given By One Enginee Fixed but and released  Fy only This is correct way
PostPosted: Sun Nov 01, 2020 3:54 pm    Post subject: Reply with quote
Substituted Frame Method of analysis is an approximate method. When one has access to software, why should one go for any approximate method ?
sknsrinivasan
PostPosted: Mon Nov 02, 2020 2:21 am    Post subject: Reply with quote
The flat slab analysed in staad as substitute frame by one engineer   So asked whether  it correct or wrong whole structure modelled in Etap he would not  like to analysis  the slab in safe  I want to know If we release Fy only what is the name of support
   I want to know degree of freedom  for spring support  and rotational spring  please explain.Here I would like to explain how much I know for spring If we release Fx,Fz and Mz  It Will be Spring But I am not sure 2-D Beam Parallel X axis k=AE/L (If the slab is resting on beam A is beam area E elastic modules  of  concrete and L span of beam) Please Correct I am Expecting Your  Reply
raghuveerks
PostPosted: Thu Nov 05, 2020 6:33 am    Post subject: Reply with quote
Dear Srinivasan Sir,
What exactly is your question? Why and what is the condition, in reality, to consider top portion of the column as fixed but and release Fy?
Is he trying to avoid axial load or effect due to lateral displacement on the column? is your column an architectural element or too slender?
your question looks interesting, but if you share your problem along with drawing others can visualise the problem easily and help you in a better way.
Thanks,
Page 2 of 3
