VPandya General Sponsor
Posted: Thu Jan 07, 2021 5:01 am Post subject: Re: I E-Mailed you the SHEAR WALL Files . |
Dear Er. Senthikumar
I e-mailed you STAAD Shear Wall files.
Vasudeo Pandya P.E.
Structural Engineer
natarajansenthil wrote: | Dear Shri Pandya sir,
Pls send me the shear wall staad flle to vnatarajansenthil@gmail.com
N Senthilkumar |
natarajansenthil General Sponsor
Posted: Thu Jan 07, 2021 5:38 am Post subject: Re: I E-Mailed you the SHEAR WALL Files . |
Thanks a lot sir.
VPandya wrote: | Dear Er. Senthikumar
Vasudeo Pandya P.E.
Structural Engineer
N Senthilkumar |
R_Shenoy SEFI Member
Posted: Thu Jan 07, 2021 6:30 am Post subject: Shear Wall design in staad |
Dear Mr Sureshkumar,
Was your original query on SEFI, about RCDC not recognising shear walls modeled with elements?
Please note that RCDC does not read or handle finite element data from Staad.
For RCDC to be effectively used, you need to model shear walls as wide columns with rigid arms - e.g a 300 x 4000 shear wall should be modeled as a column of size 300 x 4000 with a vertical prismatic member at the CG of the section, but with rigid arms modeled with very stiff beam members at every floor level, within the column from the centerline joint to joints at the column faces, along the 4000mm direction. Such rigid arms could be modeled with beam members of same width as the column/ shear wall and depth equal to floor height. Please make sure to change the attributes of such rigid beam members to zero density to avoid duplication of self weight.
I hope this will solve your problem of using RCDC for shear wall design.
Ramnath
afaq SEFI Member
Posted: Mon Jan 11, 2021 3:25 pm Post subject: |
Respected sir, could yourgood self send me staad files ,on my email id waniafaqfeb02@gmail.com.
I would be greatly obliged .
Regards afaq |
Posted: Wed Jan 13, 2021 4:13 am Post subject: I E-Mailed you SHEAR WALL STAAD FILES . |
Dear Er. Afaq ,
Vasudeo Pandya P.E.
Structural Engineer
afaq wrote: | Respected sir, could yourgood self send me staad files ,on my email id waniafaqfeb02@gmail.com.
Regards afaq |
