khaja092 SEFI Member
Posted: Sat Feb 20, 2021 7:30 pm Post subject: Regarding Design of Plinth Beam |
It can be designed as normal beam
Thanks & Best regards
Syed Affan. Director of
SK Structural designers and Project Management
Masab Tank, Garden towers, Mahara Block. #311.
Hyderabad Telangana. 500028.
Contact :00917793928335
Ujjwal SEFI Member
Posted: Sun Feb 21, 2021 2:23 pm Post subject: Plinth Beam |
Ujjwal wrote: | someshwar ganti wrote: | I feel that a Plinth beam cannot be designed as a Normal Continuous beam like that in a Roof beam.
1. the Plinth beam is Normally casted on a CRS masonry, which gives it support through out the length of the BEAM hence our normal BM equations will not really apply,
Please note for a roof beam the wall is constructed much later hence normal equations apply.
Besides the Wall load on the plinth beam, most of the sites (especially factory sheds etc) will have tractors, tippers running on the some of the bays of the plinth beams, These beams survive only because there is a CRS wall supporting the beam through out.
hence in my opinion , design it as a normal beam because the construction loads on plinth beams (atleast in some bays ) is much higher than the wall load on the beams, in such a case the CRS support below the beam will prevent the deflection etc hence the failure. |
Posted: Sun Feb 21, 2021 7:39 pm Post subject: |
Even if there are openings are there you can consider composite action- for windows you will have 2.5 feet brick wall and there will not be doors in the outside walls. You can't take 4.5 inch wall to give composite action.
quote="hishamajmalpc"]Sir,
Most of the cases there will be openings in wall (Doors/windows). Can we assume composite action in those cases?[/quote] |
