Sourabh_Agarwal SEFI Member
Posted: Wed May 10, 2017 2:20 am Post subject: Staad Select 6 series Vs Select 4 series |
Hi,
I analysed a PEB structure in both Staad Select 4 Series and Staad Select 6 Series. Results vary a lot. I have attached following in the zip.
1) screen shot of unity check in Staad Select 4 Series
2) screen shot of unity check in Staad Select 6 Series
3) Original Staad File
Can someone please help me understand the reason for the difference? |
Posted: Sun May 14, 2017 1:08 pm Post subject: |
175 views and still no reply. Can someone please help. |
Posted: Sat Jun 03, 2017 3:33 am Post subject: |
Can someone please help!!! |
rajancivildesign@gmail.co ...
Posted: Wed Jun 07, 2017 2:09 am Post subject: Result variation between Staad Pro Select series 4 and Select series 6 |
Dear Safian,
I have not gone through fully about your attachement and Staad Pro problem. In Select series you have licence fòr certain code and in select series 6 you shall be given licence for certain code. Kindly verify the licence whether you done the problem related to same code and licence is available for particular code. If it is OK, then there will be mistake in Select series 4 and 6. Please verify this fist.
Thank you.
V.M.Rajan. |
jayesh.shinde SEFI Member
Posted: Fri Aug 04, 2017 10:04 am Post subject: Staad Select 6 series Vs Select 4 series |
Check and compare analysis output of axial forces (generated by applyingmember loads on beam sections) in both staad versions. You can understand thereason for difference in strength design check for combined P-M interaction of beams. <o></o> |
