R factor in code is.1893
Raftar
PostPosted: Wed Jan 20, 2021 11:23 pm    Post subject: R factor in code is.1893 Reply with quote
Anyone, please a suggestion here??
In the 5th revision of seismic code IS.1893, the Response Reduction Factor (R) for masonry with horizontal bands is set at 2.5 (table 7 on page 23).
In the most recent 6th revision of 2016 however, (R) for masonry with bands is more conservatively reduced to 2.0 (table 9 on page 20).
https://19216801.onl/ https://routerlogin.uno/
Obviously there must be a reason for this, does anyone have any idea what the figures in this table are based on?
Is it based on rules of thumb?
Or is it based on actual calculations?
Does anyone know who worked on this; who should I approach that was involved in writing this code?
Thank you.
PostPosted: Fri Jan 22, 2021 1:56 am    Post subject: Re: R factor in code is.1893 Reply with quote
Check this:https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.nepjol.info/index.php/NJST/article/view/29802/23942%23:~:text%3DResponse%2520reduction%2520factor%2520for%2520all,is%2520sufficient%2520for%2520masonry%2520structure.&ved=2ahUKEwi28vvbtq7uAhUCy1kKHcT7B1MQFjABegQIAhAF&usg=AOvVaw3LIy_DkhZYTKF4J4pG1Pp_&cshid=1611280521902
Thank you.
PostPosted: Mon Mar 29, 2021 7:26 am    Post subject: Reply with quote
I think , response reduction factor is there  keeping  in view the balance between actual seismic forces , ductilty of structure and admissible damage without collapse of structure. A structure which do not possess ductility will fail after cracking and hence factor is very low and for rcc structures with ductile detailing provisions R factor is quiet high since structure may not collapse due to ductility , though may suffer cracking. Structures , if designed for actual seismic, would end up in abnormal requirements of sections & such an expenditure is not warranted for once in many years event of that degree.
