rajancivildesign@gmail.co ...
Posted: Fri Sep 23, 2011 5:41 am Post subject: PERMISSIBLE LEAKAGE IN MASONRY DAM |
Dear SAFIAN,
There are many dams constructed in PWD and TNEB in Tamil Nadu very long back.
Most of the dams are of masonry construction. 100% leak proof is not possible.
There is no provision in the code about permissible limit of leakage allowed in Dam. Is there any empirical formulae to find permissible leakage in Masonry Dam.
V.M.RAJAN. |
dbpatankar SEFI Member
Posted: Fri Sep 23, 2011 9:12 am Post subject: |
Following presentation gives some idea about the question you asked.
Specifically the 10th slide
http://home.iitk.ac.in/~priyog/Design%20of%20Earth%20Dam.pdf
I hope this helps. |
Posted: Fri Sep 23, 2011 9:57 am Post subject: PERMISSIBLE LEAKAGE IN MASONRY DAM |
Not involved in dam design, listing following IS codes which may
help
IS 13645 Guidelines for guniting of upstream face of masonry Dam
IS 12200 COP for provision of water stops at transverse contraction joints in masonry
and concrete dams
IS 8605 COP for construction of masonry in Dams
IS 11293(part II ) - - guidelines for design of grout curtains for masonry and conc gravity dams
best regds
vikramjeet
Dear SAFIAN,
V.M.RAJAN.
atul_123 ...
Posted: Fri Sep 23, 2011 10:06 am Post subject: |
dbpatankar wrote: | Following presentation gives some idea about the question you asked.
it is very good presentation |
prof.arc ...
Posted: Sat Sep 24, 2011 12:18 am Post subject: PERMISSIBLE LEAKAGE IN MASONRY DAM |
Dear Mr. Rajan,
I find the topic unusual for this forum as we rarely discuss "DAM"
However, assuming that you have experience in designing dams - whether plain concrete or masonry, you must be aware of design requirement for UPLIFT conditions. Most Dams - definitely all recent ones - must be having drainage galleries. I believe you must have walked through those galleries.
In quite a few, including that made of concrete, you would have noted a copious flow of water in the large gutters of the drainage gallery.
Wetness of the downstream face of a Dam is not a design worry - at the most the uplift pressure diagram may have to undergo some modification.
Even in buildings which are built in high water table region, uplift pressures must be considered and usually relief is provided by collecting the outflow in a sump and pumping it out.
It is mandatory for buildings in USA which have basement, to have a sump well and provision to pump it out.
sincerely
ARC
On Fri, Sep 23, 2011 at 11:11 AM, rajancivildesign <forum@sefindia.org (forum@sefindia.org)> wrote:
V.M.RAJAN.
lkjain.ngp SEFI Regulars
Posted: Sat Sep 24, 2011 4:19 am Post subject: PERMISSIBLE LEAKAGE IN MASONRY DAM |
Permissible leakage should depend up on following criteria.
1. Exit velocity of leaking water should be less (by margin of factor of safety) than the one which can cause erosion of the mortar in the masonry. Loss of strength of masonry will also result in reduced life of dam.
2. Masonry dam's main purpose is to store water. and leakage means loss of precious water. Hence leakage should be negligible for economic advantage of dam.
L. K. JAIN
On 23 September 2011 11:11, rajancivildesign <forum@sefindia.org (forum@sefindia.org)> wrote:
V.M.RAJAN.
freedom SEFI Member
Posted: Sat Sep 24, 2011 6:26 am Post subject: PERMISSIBLE LEAKAGE IN MASONRY DAM |
what should be the exit velocity? quantitative wise
Posted: Sat Sep 24, 2011 8:00 am Post subject: PERMISSIBLE LEAKAGE IN MASONRY DAM |
Thank you for the information given in the forum. The ppt given is for earthen dam. Also as mentioned by Prof. Arc Drainage Gallery is provided in Masonry Dam for the leakage purpose. There is no accurate formula for calculating leakage. A thumb rule for calculating leakage is {0.01 x Wetted area in sq. feet/1.75} in gallons per minute. This can be converted in terms of litres/ minute. I don't know whether this formula is used for calculating leakage in practice.
V.M.RAJAN. |
ishwarch59 SEFI Member
Posted: Fri Apr 02, 2021 10:47 am Post subject: Re: PERMISSIBLE LEAKAGE IN MASONRY DAM |
rajancivildesign@gmail.co wrote: | Dear SAFIAN,
V.M.RAJAN. |
Posted: Fri Apr 02, 2021 10:52 am Post subject: Re: PERMISSIBLE LEAKAGE IN MASONRY DAM |
ishwarch59 wrote: | rajancivildesign@gmail.co wrote: | Dear SAFIAN,
V.M.RAJAN. |
Dear Rajan,
Please refer CWC" Report on Dam Safety Procedures" available online. |
