Murali Rapelli SEFI Member
Posted: Thu Jun 03, 2021 6:46 am Post subject: Connection type definition in staad |
Hello Forum,
I need some clarity on how to define this type of joint in staad for analysis.
Two beams are joined together by a male and female lug plates and a pin is inserted after matching. This is a temporary structure and has to be dismantled again before moving to next location.
Can it be considered a rigid joint?
The distance between pin and pin hole is less than 1 mm |
