STAAD PRO DESIGN RESULT ISSUE ON STEEL DESIGN AS PER CODE IS800 LSD
abhijit das
PostPosted: Thu Jun 10, 2021 6:16 pm    Post subject: STAAD PRO DESIGN RESULT ISSUE ON STEEL DESIGN AS PER CODE IS800 LSD Reply with quote
Dear Sefian
since a long time , I facing a problem on steel design in staad pro V8i ss6 software, while design is perform as per code IS800 LSD, even defining the load list command as envelope or "load list - to -", the member is designing out of the defining load list. Its perform ok when is design as per "CODE INDIAN" (working stress method).
I am become hopeless after reinstall the software for 3 times. I cant understand, what is the issue and even i asked to many friends but no one can help me.
I request to all, please help me.
abhijit das
PostPosted: Fri Jun 11, 2021 8:18 am    Post subject: Reply with quote
Dear Er
Just to say that please see user's manual of this version and find if it helps.
Worked on WSM only for steel strs.,, even on staad and hence not sure where problem lies in working on LSM design of steel strs.
P.Manoharan
PostPosted: Tue Jun 15, 2021 3:33 pm    Post subject: Re: STAAD PRO DESIGN RESULT ISSUE ON STEEL DESIGN AS PER CODE IS800 LSD Reply with quote
abhijit das wrote:
Dear Sefian
abhijit das
P.Manoharan
PostPosted: Tue Jun 15, 2021 3:34 pm    Post subject: Re: STAAD PRO DESIGN RESULT ISSUE ON STEEL DESIGN AS PER CODE IS800 LSD Reply with quote
abhijit das wrote:
Dear Sefian
abhijit das
PostPosted: Wed Jun 16, 2021 3:29 am    Post subject: Reply with quote
Dear Er P.Manoharan,
Yr Yeply is not appearing with quote from originator of query.
Pl try to send yr reply without quote.
P.Manoharan
PostPosted: Wed Jun 16, 2021 4:37 am    Post subject: Is 800 LSD input in staad Reply with quote
Dear Er
You have to input in staad as
"CODE IS 800 LSD"
and run the staad
Don't put CODE INDIAN
This is for WSD -1984 code
