Brick wall plastering using sand zone
srikrishnagrandhi
PostPosted: Fri Dec 21, 2018 7:13 pm    Post subject: Brick wall plastering using sand zone Reply with quote
Dear sefins,
Which type of sand zone used for plastering.as per is code
G.srukrishna
sspawar
PostPosted: Fri Oct 22, 2021 11:49 am    Post subject: Reply with quote
Dear Sefian,
For plaster sand - sand should be generally 100% passed through 2.36 mm sieve.
SIEVE ANALYSIS FOR PLASTER SAND-as per Specification IS: 1542 1992 (RA 2014)
IS Sieve
Designation,                                                 Cumulative Percent,              Requirement of Sand for Plastering as per Specification IS: 1542 1992 (RA 2014) Retained Passing
10.00mm0100100
04.75mm010095-100
02.36mm0.699.495-100
01.18mm14.685.490-100
600 Microns30.469.680-100
300 Microns50.649.420-65
S S Pawar
PostPosted: Fri Oct 22, 2021 2:32 pm    Post subject: Reply with quote
Exposed Plastering is generally done using 1 cement :3  Fine  sand . But mixing some 1 part out of 3 parts coarse sand is beneficial for durability , though specs are for fine sand plaster.
For Plastering on walls needing Tiles finish , plaster shall be from all coarse sand in ratio 1:3.
Before plaster application walls must be watered on face followed by  flashing of cement slurry. Also curing of plaster shall be done religiously.
Just a thought for durability.
