logeshcivil SEFI Regulars
Posted: Fri May 27, 2022 6:34 am Post subject: |
Dear vikram
Thank you for your prompt repose.Your replies are of immense help to me. _________________ Yours
Er. S.Logesh |
Joined: 21 Feb 2008 Posts: 5499 Location: Gaithersburg, MD, U.S.A.
Posted: Tue May 31, 2022 4:28 pm Post subject: |
vikram.jeet wrote: | Anchors need to be designed for horizontal shear force . For design philosophy you can refer IRC code on composite bridge decks. You can also see Dr VK Raina book on Bridge Designs /any book on composite designs.
Normally I do not check the files for which seek pardon. |
Dear Er Vikramjeet,
I have included the design of Anchors in my book on Design of RC Structures, Oxford University Press !
Warm regards
Subramanian |
Posted: Wed Jun 01, 2022 2:51 am Post subject: |
Dr. N. Subramanian wrote: | vikram.jeet wrote: | Anchors need to be designed for horizontal shear force . For design philosophy you can refer IRC code on composite bridge decks. You can also see Dr VK Raina book on Bridge Designs /any book on composite designs.
Dear Er Vikramjeet,
Warm regards
Subramanian |
Er Logesh ,
As enlightened by respected Dr NS Sir , you can refer book on rcc Designs authored by him for design of Anchors in composite construction works. This book is latest on rcc design theory and practice. |
Posted: Thu Jun 02, 2022 4:35 am Post subject: STRENGTHENING OF BEAMS |
Dear sirs
Thank you very much for valuable suggestion
sir.I will look into it. _________________ Yours
Er. S.Logesh |
spsvasan ...
Posted: Sun Jun 05, 2022 5:10 am Post subject: Re: STRENGTHENING OF BEAMS |
logeshcivil wrote: | Dear sefians
I have attached some files for your reference.Help me with this.In this structure they have provided 9" x 2' beam (M20) beam for 60' span. I think that it will cause excessive deflection. So i am planning on providing rectangular section or I section as column for additional support. When trying to design anchor bolt , it fails in cone failure.Some suggested that I should try designing the anchor bolt with pinned connection. How do i do that.
Do i release the moments in the column in the STAAD model or how should i go about it.
Or
Any other suggestions for the strengthening of the beams. |
Dear Er.Logesh and other SEFIans
I hope this is not an actual structure under construction.
I request SEFIans to look into the beam layout and details attached by Er.Logesh in his first posting and comment on the same
From the geometry of the layout it looks as if B10 and B12 will behave as main beams and B7 will behave as a secondary beam. The detailing of B10 and B12 does not reflect this behaviour. Also, the detailing of the cantilevers seems to be poor
S.P.Srinivasan |
