Support conditions for analyzing G+1 Building
ramu_se
PostPosted: Thu Jun 09, 2022 9:23 am    Post subject: Support conditions for analyzing G+1 Building Reply with quote
At what consideration do we need to fix the support conditions for analyzing the building?
For example, if we analyze a G+1 or G+2 building using Etab or staad software
do we need to assign the fixed support or pinned support?
Kindly Clarify.
Thanks,
Ramu.
PostPosted: Fri Jun 10, 2022 3:10 am    Post subject: Reply with quote
Buildings - support condition
Isolated footings resting on Rock  / Hard strata. - Fixed
Isolated footings resting on medium/ weak soils -
With foundation tie beams - Fixed
Without foundation tie beams - Pinned
Reason being that in weak stratas , a slight rotation of footing result in compatibility moment to cease in case tie beams are not there.
However in manual analysis , for  medium/weak soils , the support condition pinned for Gravity loads And Fixed for EQ/wind  (in case found tie beams not provided). But in softwares only one support condition to be given.
RAFT FOUNDATION - FIXED
pvgraju
PostPosted: Fri Jun 10, 2022 5:26 am    Post subject: Support conditions for analyzing G+1 Building Reply with quote
Columns resting on raft, piles raft ,isolated footings on hard soil can be treated as fixed.
Isolated footings resting on soft soil are pinned. But instead of treating as pinned springs can be assigned based on soil stiffness for more reliable values.
P.V.Gavarraju.
logeshcivil
PostPosted: Fri Jun 10, 2022 6:59 am    Post subject: Reply with quote
Dear sir
Can you specify the support conditions based on safe bearing capacity of soil?
Yours
Er. S.Logesh
PostPosted: Fri Jun 10, 2022 9:41 am    Post subject: Reply with quote
SBC  less than 7.5 T/m2  - is weak strata
SBC of 7.5 to 12 T/m2 is medium strata
SBC  of 12 to 18  T/m2 or more Hard strata
Just to say
However as per NBC , strata with N values for cohesion less soils  as well as ucs values for cohesive soils are classified in these categories and  can be referred.
PostPosted: Fri Jun 10, 2022 10:05 am    Post subject: Reply with quote
Cohesion less soils :
SPT N value  less than 10  - - Soft Soils
SPT N value 10 to 30 - -  Medium soils
SPT N value greater than 30 - - - HARD SOIL / ROCK
As per NBC
PostPosted: Fri Jun 10, 2022 3:15 pm    Post subject: Re: Support conditions for analyzing G+1 Building Reply with quote
pvgraju wrote:
P.V.Gavarraju.
Yes , very apt  answer from Er PV Gavarraju .
It will give best results .
