Error in ETABS in finding compression reinforcement for gravity loading combination as per IS 456
Kaustav Sengupta
PostPosted: Wed Jul 13, 2022 6:15 am    Post subject: Error in ETABS in finding compression reinforcement for gravity loading combination as per IS 456 Reply with quote
Hi Everyone,
I have a 2D moment frame RC building building modelled in ETABS. I am doing gravity analysis and design for 1.5DL+1.5LL+1.5SDL load combination. I have doubts,
1. that why am I getting positive moments (marked by red color, attachment) in the compression zone in the support section as well as a mid section? It should be ideally zero.
2. Secondly, why is the bending moment by analysis different from the bending moment after the design by IS 456? How can I make it same value?
Kindly help and support.
Thank you.
 Filesize:  168.31 KB
 Viewed:  37 Time(s)
2storey_5mbaylength_rigidjoints_Reinfapplied.zip
 Filename:  2storey_5mbaylength_rigidjoints_Reinfapplied.zip
 Filesize:  225.42 KB
 Downloaded:  64 Time(s)
mjnasar
PostPosted: Tue Jul 26, 2022 12:25 pm    Post subject: Reply with quote
Dear Engineer
Greetings
please remove the joint restraints at storeys
[IMG]data:image/png;base64,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
