Posted: Fri Jun 24, 2022 3:26 am Post subject: |
Concrete Block Foundation :
Despite many advantages discussed in previous posting , the excavation of block is time consuming as it is to be done manually so that side soil is not disturbed . Also block size need to be at least 900x900 mm or higher for manual working excavating.
In case JCB is used for excavation , side shuttering / 4.5" brick wall is needed before concreting. Also in such situation side backfill around block needs compaction .
But still is an economical and faster when compared to conventional spread footing with top and bottom meshes concreting first and pedestal concreting afterwards. |
Posted: Sat Jul 09, 2022 7:27 am Post subject: |
Footing Base contact Vs Factor of Safety against Overturning
Footings subjected to Uniaxial Moment AND Centric weight /Loading
Generally footings of sheds , Masts or Concentric Column loadings etc
Eccentricity e = W/M
W is the net con centric weight on Footing including self wt of footing and soil over it.
M is the moment Overturning due to horizontal forces
Contact Length X = 3 ( B/2 - e )
contact C = X/B
B is the Length of footing in direction of moment
Stabilizing Moment = W * B/2
FOS (OVERTURNING) F = (W*B/2) / M = (W/M) * (B/2) = (1/e)* (B/2)
e = B /(2F)
X = 3( B/2 - e ) = 3[B/2 - {B / (2F)}]
X/B = 1.5 - 1.5/F
C= 1.5 - 1.5/F
F = 1.5 / (1.5 -C)
Result as under :
If contact length = 50% I.e C = 0.5 , FOS OT = 1.50
If contact length = 66.7% C = 0.667 , FOS OT = 1.80
If Contact length 75% C = 0.75 FOS OT = 2.0
IF Contact length 90% C = 0.90 FOS OT = 2.50
IF CONTACT Length = 99.99% C = 1.0 FOS OT = 3.0
Therefore just by working out Footing base Contact , Fos on overturning is known . |
Posted: Sat Jul 09, 2022 8:12 am Post subject: |
In continuation of previous post :
BASE contact area is , since reduced , maximum base pressure needs to be within permissible limits
The maximum base pressure = 2W / (X*L)
L is the length of footing in other direction
( B is the length of footing in direction of moment as stated in previous post) |
Posted: Wed Jul 13, 2022 6:06 am Post subject: |
I DESIGN , HE SUPPORTS
Success of any civil construction is dependent on many factors :
Soil Investigation to be done properly and recommendations need to be firm
Structural design & Detailing needs to be perfect
Construction materials tested and upto desired standards
Experienced Construction Agency with zero tolerance to bad Quality , Corruption and laxity
Workman ship to be best
Quality control to be maintained throughout
Safety standards not be compromised
Only a strong Team can deliver with fulfillment of above .
A wise Doctor always write behind his sitting chair :
I TREAT , HE CURES
A wise Designer do write the same :
I DESIGN , HE SUPPORTS |
Posted: Fri Jul 29, 2022 10:31 am Post subject: |
Small Shed Foundations
In practice Large / Small shed foundations are in form of spread footings at 1.2m - 2.0 m foundation depths depending on uplift forces from roof and lateral forces on roof and cladding causing moments as result of Wind conditions.
However in some previous posting it was discussed that rcc block foundations are also economical , but these require Block depths in excess of 1.2 to 1.5 m .
But for Small sheds it is further economical and faster to provide Rcc / steel girder tie beams in transverse direction at or just below Plinth Level , tie-ing all opposite columns , which can resist lateral moments from columns fully . The uplift force can be balanced by providing rcc block and a smaller size with shallow depth of rcc block suffice as it balances the uplift force with some fos.
Only thing while suggesting such transverse tie beams introduction is that these beams , though are at PL , shall not interfere with any functional requirement beneath plinth , say in form of furnace etc.
The peripheral rcc beams are to be provided as usual , but above note is regarding provision of transverse tie beams which exclusively provide double benefit , (i) to resist lateral column moments fully (ii) to provide weight to foundation block to resist uplift thereby help in reducing block foundation size. |
Posted: Tue Aug 16, 2022 5:18 am Post subject: |
Structural engineers patience :
Patience of engineers engaged in structural design profession is always on test. Mostly if everything moves smoothly , there seems no problem but many occasions create unfavorable and unacceptable situations for them causing them to be rigid , blunt , and even losing temperament. Even a very jolly and humorous engineer can reverse gears in technically unfavorable environment , be it at design office or at site execution.
At design office :
(i) In case Senior SE is asking to reduce , design which str engineer engaged feels as under design , he will argue , may become irritated unless instructions are in writing .
Many CR's were spoiled due to this .
(ii) Proof Consultant is asking for some review which SE feels is not in direction of str safety . It seen that prime engineers may lose patience.
EXECUTION:
(i) Execution done wrongly with under reinf , and SE is asked to prove it OK.
( ii) On site visit , many execution flaws in placement and site not agreeing to correct and blaming drgs for poor detailing.
As Review Consultant :
(i)Review designer feel something in direction of undersafety/stability and pin point , but prime designer not ready to appreciate .
( to be continued ) |
Posted: Tue Aug 16, 2022 9:30 am Post subject: |
Structure Engineers patience
Continuing from previous post - many situations are mentioned wherein even a humble , jolly , humorous structure engineer may feel uncomfortable due to reasons none other than purely technical. The main reasons for uncomfort are many :
(i) Responsibility of Structural safety is innate in designers
(ii) Structure work is calculations oriented and only designer is knowing the quantum of physics and mathematics inherent in it . For others not associated with design, it is just a routine work which can be modified here and there.
(iii) structure job is not rosy , any small changes may interfere with long calculations/ analysis just jeopardizing with str safety
(iv)Str design is primarily based on Collapse mechanism . Designer right from college to design office is in thinking to keep materials away from their failure ranges . Collapse / Failure which is a negative aspect , but SE has to think / visualize while working as part of profession .
(v) Designer always think of Concrete , Steel and building materials ( and not of flowers , roses), mostly , while working on designs and this thinking environment prevail in his attitude . That is why it seen that most designers of structures are inclined to music , poetry or any positive activity to disconnect from this materialistic domain and connect to some finer aspects .
(vi) Designers work is 2x2 =4 neither think of providing 4. 1, nor provide less and also sometimes lose patience to resist providing 3.9 . I.e. underprovision . Flexibility domain is very narrow for Str Er as compared to other professionals .
But a professional has to deal all situations . A soldier is battle hard and has to fight without fear , so is the case with Structural engineer whose main aim is to provide safe designs with due diligence to economy and construct ability. |
