Few IS codes related to special structures
PostPosted: Tue Jul 13, 2010 9:46 am    Post subject: Few IS codes related to special structures Reply with quote
Dear Engineers
List of few important IS Codes
Special Structures related
Ports & Harbours
9527(pt1) cop for design and construction of port & harbour structures--conc monoliths
9527(pt3) cop for design and construction of port & harbour structures--sheet pile walls
9527(pt4) cop for design and construction of port & harbour structures--cellular sheet pile walls
4651 cop for planning and design of port & harbour structures (5 parts)
IS 4651 : Part 1 : 1974 Code of practice for planning and design of ports and harbours: Part 1 Site investigation
IS 4651 : Part 2 : 1989 Code of practice for planning and design of ports and harbours: Part 2 Earth pressure
IS 4651 : Part 4 : 1989 Code of practice for planning and design of ports and harbours: Part 4 General design consideration
IS 4651 : Part 5 : 1980 Code of practice for planning and design of ports and harbours: Part 5 Layout and functional requirements
IS 4651 : Part III : 1974 Code of Practice for Planning and Design of Ports and Harbo
10020 recommendations for design and construction of port & harbour components--slipways
13746 geotechnical investigation of off-shore jacket structures
4111(pt3)cop for ancillary structures in sewarage system--pumping stations and pumping mains
2751 recommended practice for welding of plain and deformed bars for rc construction
9417 recommendations for welding cold worked deformed bars for rc construction
2204 cop for construction of reinforced concrete shell roof
2210 criteria for design of reinf. Conc. Shell structures and folded plates
2750 steel scaffoldings
10262 recommended guidelines for conc mix design
3935 cop for composite construction
4090 criteria for design of reinforced concrete Arches
4091 cop for design and construction of foundations for transmission towers
11233 cop for design and cons of Radar antena,Microwave TV Tower station
4995 criteria for design of reinf. Conc. Bins for storage of granular and
powdery materials (2parts)
9178 criteria for design of steel bins for storage of bulk materials (3parts)
4998 criteria for design of reinforced concrete chimneys
6533(pt1) cop for design and construction of steel chimneys--mechanical aspects
6533(pt2) cop for design and construction of steel chimneys ---structural aspects
11504 criteria for structural design of reinf conc. Natural draught cooling towers
11561 cop for testing of cooling towers
11682 criteria for design of RCC staging for overhead water tanks
12303 criteria for design of reinf. Conc. Hinges
13591 criteria for design of lifting beams
14458(pt1) retaining walls for hill area---selection of type of wall
14458(pt2) retaining walls for hill area---design of retaining/breastwall
14458(pt3) retaining walls for hill area--construction of dry stone wall
8686(pt1) cranes -design principles for loads and loads combinations--general
8686(pt5) cranes -design principles for loads and loads combinations---OHT and portal bridge cranes
14467 cranes --wind load assessment
5525 recommendations for detailing of reinf. In reinforced conc. Works
6494 Water proofing of UG Reservoir and swimming pools
13301 cop for vibration isolation of Machine foundations
5525 Recommendations for detailing of RC Structures
6505 cop for installation of joints in conc pavements
7861 Extreme weather concreting
IS 4996 : Specification for reinforced concrete fence posts
6922 criteria for safety and design of stuctures subjected to UG Blast
4991 criteria for blast resistant design of structures for explosion above ground
2553 Specifications for SafetyGlass
-- ญญ
Thankful People
PostPosted: Fri Apr 23, 2021 11:02 am    Post subject: Some useful References Reply with quote
Blank
Repeat post deleted
PostPosted: Fri Apr 23, 2021 11:30 am    Post subject: Some useful References Reply with quote
Repeat post deleted
PostPosted: Fri Sep 23, 2022 7:23 am    Post subject: Reply with quote
Blank
